Graduate Why is this C-G coefficient always zero?
  • Thread starter Thread starter euphoricrhino
    Coefficient Zero
The discussion centers on the observation that the Clebsch-Gordan (C-G) coefficient for the state |j=l,m=0⟩ with the component |j_1=l,j_2=1;m_1=0,m_2=0⟩ is always zero. This is attributed to the angular momentum addition rules, specifically that the vectors involved cannot form a triangle in the context of angular momentum states. The analogy of adding classical vectors is used to illustrate that the resulting vector cannot equal the original when the components are in the same plane. The participants explore the implications of this zero coefficient and consider mathematical proofs, including the Wigner-Eckart theorem, to reinforce the understanding of the underlying principles. Ultimately, the discussion highlights the complexities of angular momentum addition and the conditions under which certain states can or cannot exist.
euphoricrhino
From calculating a few CG-coefficient tables, it occurred to me that when we add two angular mometa ##j_1=l## and ##j_2=1## (with ##l## whole integer), the resulting ##|j=l,m=0\rangle## state always has zero C-G coefficient with ##|j_1=l,j_2=1;m_1=0,m_2=0\rangle## component, i.e., ##\langle j_1=l,j_2=1;m_1=0,m_2=0,|j=l,m=0\rangle=0##.
But the usual C-G coefficient selection rule only dictates ##|j=l,m=0\rangle## may have components in 3 states ##|j_1=l,j_2=1;m_1=-1,m_2=1\rangle, |j_1=l,j_2=1;m_1=0,m_2=0\rangle, |j_1=l,j_2=1;m_1=1,m_2=-1\rangle##. Why was the middle state ##|j_1=l,j_2=1;m_1=0,m_2=0\rangle## forbidden? Is there deeper insights?
Thanks
Likes PeroK
Think about classical vectors. You want to add ##\ket{1,0}## to ##\ket{l,0}## and still get ##\ket{l,0}##, i.e., you want to add a vector of length ##\sqrt{2}## to a vector of length ##\sqrt{l(l+1)}## and recover a vector of length ##\sqrt{l(l+1)}##, while all 3 vectors lie in the xy plane. Can't work.
Likes PeroK, Vanadium 50 and topsquark
Thanks for the reply, but I'm sorry I don't really understand this analogy.
Where I got lost is the part when you say "all 3 vectors lie in the xy plane", which 3 vectors are you referring to (it seems you are referring to the ##|m_1=1,m_2=-1\rangle,|m_1=0,m_2=0\rangle,|m_1=-1,m_2=1\rangle## as the 3 vectors in xy plane?)
I'm also not understanding what "add a vector of length ##\sqrt{2}##" mean, since we are talking about projection of vector of length ##\sqrt{l(l+1)}## onto 3 vectors of length ##\sqrt{2}## while one of the projection has zero projected components.
Clebsch-Gordan coefficients are used in the addition of angular momenta, so one can use a the analogy of adding classical vectors. In this case, you have a state ##\ket{j,m}## that is the result of the addition of states ##\ket{j_1,m_1}## and ##\ket{j_2,m_2}##, in particular
\ket{j=l,m=0} = \sum_{m_1,m_2} \ket{l,m_1,1,m_2} \braket{l,m_1;1,m_2 | l, 0}
and ask why ##\braket{l,0;1,0 | l, 0} = 0##. The reason is that since ##m=m_1=m_2 = 0##, the two vectors being added, namely ##\ket{l,0}## and ##\ket{1,0}##, are in the xy-plane, but so is the resulting vector you are considering, and therefore the CG coefficient can only be ##\neq 0## is making a triangle out of the three vectors is possible, which is not the case if ##j=l## while ##j_1=l## and ##j_2=1##.
This is similar to the fact that ##\braket{j_1,m_1;j_2,m_2 | j, m} = 0## if ##j < |j_1-j_2|## or ##j > j_1+j_2## (triangle rule) or if ##m \neq m_1 + m_2##, as these conditions also lead to an arrangement of three vectors that is not a triangle.
Likes PeroK, topsquark and euphoricrhino
Thanks a lot for the elaboration. I think I'm forming the mental picture now. You are suggesting to visualize any state ##|j,m\rangle## as a 3-D vector of length ##\sqrt{j(j+1)}## whose ##z##-component is ##m##, and claim CG coefficient to be non-zero only if the 3 vectors involved can form a triangle.
Am I understanding your analogy correctly? I can see how this can help prove my original observation.
Thanks a lot again!
Likes DrClaude
Thinking about it a little more, I think I'm still not understanding the analogy (despite my earlier claim that I did). Take the example where we add ##|l=1,0\rangle## with ##|l=1,0\rangle##, and we are asking why the resulting angular momentum cannot be ##|l=1,0\rangle##. By the analogy, these are three vectors on xy plane, each of which has length ##\sqrt{2}##, and the claim was they cannot form a triangle. But they can, as equilateral triangle, right?
You're making me doubt my answer! I'll have to think a bit more about it.
Now I think I finally come up with a proof for this claim using Wigner-Wickart theorem. The proof is simple but "mathematical", so some physical insights are still appreciated.
Here's the proof -
Consider the vector operator ##\mathbf{J}##, and transform it into "spherical tensor of rank-1" form
T^{(1)}_{\pm1} = \mp(J_x\pm iJ_y), \qquad T^{(1)}_0=J_z
By Wigner-Eckart theorem,
\left\langle j=l,m=0|T^{(1)}_q|j_1=l,m_1=0\right\rangle = \langle j_1=l,j_2=1;m_1=0,m_2=q|j=l,m=0\rangle\frac{\langle j=l||T^{(1)}||j_1=l\rangle}{\sqrt{2l+1}}
But for ##q=0##, the LHS vanishes because ##T^{(1)}_0=J_z##, which means the CG coefficient on the RHS must vanish because the second factor on RHS, being the same for all ##m## and ##q## values, must be non-zero.
  • · Replies 20 ·
