What's wrong with this proof for the set C={a1}?
  • Thread starter Thread starter Vishera
    Proof
The proof for the set C={a1} is invalid because it incorrectly assumes that C and B can be equal while excluding an element from set A, specifically a2. The argument fails when it states that set A consists of k+1 numbers, which can be identical or distinct. This oversight leads to a contradiction, as it implies that not all elements of A are accounted for in B or C. Therefore, the proof collapses at the point of defining set A. The logical inconsistency renders the entire argument unsound.
Vishera
Why can't C={a1}?
Which part of
The reason is that C = {a1} = B, so an element of A, namely a2, is not in either B or C.
don't you understand?
Likes 1 person
The proof clearly falls apart when it is stated let Set ##A## be a set of ##k+1## numbers. These number can either be all the same, or different. Hence the proof is invalid from that point on.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
