Why is Vg negative in this circuit interconnection?
8 replies · 3K views · last reply
sevag00
Hi. I have an electric circuit attached below. The question is to find the value Vg in order for the interconnection to be valid. The answer is -2V.
My question is, why is the voltage minus?
  • Circuit schematic with three parallel branches between a top and bottom node: a dependent voltage source labelled i_b/4 on the left, an independent voltage source labelled v_g with its + sign at top in the middle, and a current source of 8 A on the right. Current i_b is labelled with an arrow pointing left at the top right.
You did the calculation - if you read the diagram correctly you set the [+] terminal to have a higher voltage than the [-] terminal. The minus sign means that the terminals are drawn the wrong way around.
As to "why", you may have done the calculation wrong or maybe that's just the way the physics works out for that configuration.
I doubt there is miscalculation, because the book had already given the answer key.
Show how you would determine the potential of the controlled source on the left.
ib=8A, Vx= ib/4 = 8/4=2V
Check the defined direction of ib. Is the 8 A source really driving current in the direction indicated?
Oh. You mean they are in opposite direction. So the current ib is negative, right?
Right.
