Why is voltage called potential difference?
Voltage is defined as potential difference, which refers to the difference in electric potential energy between two points in a circuit. This concept is analogous to gravitational potential energy, where a brick held at a height has potential energy due to its position. Even when a circuit is open, voltage exists across the switch, akin to pressure in a water pipe, indicating that potential is present regardless of current flow. Thus, voltage and potential difference are synonymous terms in electrical circuits.
  • Understanding of basic electrical concepts, including voltage and current.
  • Familiarity with electric potential energy and its relation to circuit behavior.
  • Knowledge of circuit components, such as batteries and switches.
  • Basic grasp of analogies in physics, such as comparing electrical systems to hydraulic systems.
  • Research the relationship between voltage and current in Ohm's Law.
  • Explore the concept of electric potential energy in circuits.
  • Learn about measuring voltage in live circuits using multimeters.
  • Investigate analogies between electrical systems and fluid dynamics, particularly pressure and flow.
Students of physics, electrical engineers, and anyone seeking to understand the principles of voltage and potential difference in electrical circuits.
Jack
"Potential" refers to potential energy -- for example, a test charge at rest in an electric field has potential energy. In a similar way, a brick held in the air has gravitational potential energy.
Between two points at different heights above the ground, there is a difference in potential. Between two points in a circuit with different voltages, there is a difference in potential. A voltage is a difference in potential, or a potential difference.
- Warren
- Warren
But it's not potential is it because there isn't a voltage before you switch the circuit on. If this statement is wrong then I still don't understand and then could someone else please try explaining it to me.
If there's no voltage, then there is no potential difference, that's correct. "Potential difference" is synonymous with "voltage."
The two ends of a AA battery have two different electric potentials; therefore, the battery presents a potential difference (or voltage). When you connect it to a circuit, the potential difference coaxes charges to move.
In a similar manner, when you let go of the brick you're holding in mid-air, the brick is coaxed to move by the difference in gravitational potential.
- Warren
The fact is circiut source voltage is present across an open switch. The way to find an open in a live circiut is to measure voltages, looking for a wire or connection that measure source voltage.
There is your potetial.
Try thinking of it as pressure. A good analogy is water in a pipe. Voltage is the pressure whether the switch or valve is open or not. Current or amperage is the amount of water or electrons that flow. Obvisously when the switch is open there is no current flow but the pressure i.e. voltage/potenial is still there.
  • · Replies 25 ·
  • · Replies 21 ·
  • · Replies 58 ·
