Why is x > 0 not an open interval?
  • Thread starter Thread starter maverick280857
    Interval
The discussion centers on the distinction between open sets and open intervals in mathematics, specifically regarding the set X = {x ∈ ℝ | x > 0}. While X is identified as an open set and an interval, it is not classified as an open interval because it does not conform to the definition requiring both endpoints to be real numbers. The conversation highlights that open intervals must have finite endpoints, which excludes infinity from being considered as a valid endpoint in this context. Participants clarify that the definitions used in certain mathematical texts may emphasize this distinction, leading to confusion. Ultimately, the consensus is that X is an open set but not an open interval due to the nature of its endpoints.
maverick280857
Hi,
This might be a trivial question, but I'll ask it anyway.
Lectures on Advanced Mathematical Methods for Physicists by Sunil Mukhi and N. Mukunda said:
X=\{x\in\mathbb{R}\,|\,x > 0\}
is an open set. This is not, however, an open interval.
Why is this not an open interval? Let a, b be two elements in X, such that a < b. Then, every real number c satisfying the order relation a < c < b is necessarily in (a, b) and hence in X. Hence X is an interval. Since X is equivalent to the interval (0, \infty), I assumed it is also an open interval. Does the definition of an open interval only apply to intervals with finite end points? I thought otherwise: http://en.wikipedia.org/wiki/Interval_(mathematics)#Infinite_endpoints.
Thanks in advance.
I don't know the reference and thus the context, but are you sure the authors are not referring to a 'bounded interval' ?
Or are the authors distinguishing between the reals (which do not contain \pm \infty ) and the extended reals which do?
This distinction is often ignored.
Look in that book for the definition of "open interval". Your set is an open set and an interval, but perhaps there is a technical definition of "open interval" used in that book, requiring an "open interval" to have the form (a,b) with b a real number.
Thanks for the replies. This is what the book says
Open interval: (a, b) = { x \in \mathbb{R} | a &lt; x &lt; b }
Closed interval: [a, b] = { x \in \mathbb{R} | a \leq x \leq b }
A closed interval contains its end points, while an open interval does not.
Definition: X \subset \mathbb{R} \implies x \in (a, b) \subset X for some (a, b)
"..a subset X of R will be called open if every point inside it can be enclosed by an open interval (a, b) lying entirely inside it."
No mention has been made of whether a and b must necessarily be finite.
and what is the book's definition of R ?
does it contain infinity (the extended reals)
or not (the reals)
What are a and b? Most likely, the book wants a,b to be elements of R.
Nothing else is listed explicitly. I would assume that a and b are elements of R too. But no mention is made of whether a and b can be infinite.
If it turns out out that a,b are supposed to be members of R, then it makes sense that (5, infinity) is not an open interval (because open sets are the ones of the form (a,b) where both a AND b are in R. (infinity is not in R).
Ah. Thanks.
I guess you meant to write "open intervals" instead of "open sets". (The example was said to be an open set but not an open interval.)
You read my mind, thank you for the correction.
  • · Replies 32 ·
