Why M.Planck used Boltzman distribution to calculate average energy?
  • Context: Undergrad
  • Thread starter Thread starter aliinuur
The discussion centers around the reasons why Max Planck utilized the Boltzmann distribution in his calculations of average energy, particularly in the context of blackbody radiation. Participants explore the relationship between Boltzmann's principles and Planck's approach, touching on classical and quantum physics implications.
  • Some participants argue that kT defines the scale of the Boltzmann distribution, suggesting that average energy and the Boltzmann distribution are equivalent.
  • Others contend that Planck's intention was to avoid the Boltzmann distribution due to its failure to address the ultraviolet catastrophe, indicating a fundamental misunderstanding of the subject by some participants.
  • A participant explains that while both classical and quantum physics compute average energy using a similar formula, the distinction lies in the nature of the states summed over, with classical physics using phase space and quantum physics using a Hilbert space basis.
  • Another participant notes the difference between the Maxwell-Boltzmann distribution and the more general Boltzmann factor, emphasizing that the mean energy is only equal to kT under specific conditions.
  • Some participants highlight that Planck initially viewed the radiation field as continuous and introduced the concept of quantized energy exchange as an ad hoc solution to apply Boltzmann's methods.
Participants express conflicting views on whether Planck used the Boltzmann distribution in his calculations. There is no consensus on the interpretation of Planck's approach or the implications of the Boltzmann distribution in this context.
Participants reference various assumptions about the nature of energy exchange and the mathematical formulations involved, but these assumptions remain unresolved and are subject to differing interpretations.
aliinuur
TL;DR
As far as I understand kT defines scale of Boltzman distribution, i.e. avg. energy and Boltzman distr. are the same thing. And for me, Planck's move to find avg. energy different from 1/2kT from Boltzman distr. is like 1+1=2, 2-1=3.
As far as I understand kT defines scale of Boltzmann distribution, i.e. avg. energy and Boltzmann distr. are the same thing. And for me, Planck's move to find avg. energy different from 1/2kT from Boltzmann distr. is like 1+1=2, 2-1=3.
Science news on Phys.org
If you think Planck used the Boltzmann distribution, you are quite mistaken. The whole point of Planck's paper was to not use the Boltzmann distribution, because that distribution predicted the ultraviolet catastrophe, which was obviously a very wrong prediction.
I'm not sure what the point is of your post, but per the above you seem to have a basic misunderstanding of this subject.
Both classical and quantum physics in a canonical ensemble compute the average energy by the formula of the form
$$\langle E\rangle = \frac{\sum_s E_s e^{-E_s/kT}}{\sum_s e^{-E_s/kT}}$$
where the sum is taken over all states ##s##, so at a first look it may appear that both are based on Boltzmann distribution. However, classical and quantum physics differ by the set of states ##\{ s \}##, i.e. the sum is performed differently. In classical physics the sum is really the integral over phase space, namely, the Boltzmann distribution is a distribution over phase space. By contrast, in quantum physics the sum is performed over a basis of a Hilbert space, so the corresponding distribution is not the Boltzmann distribution, Boltzmann did not know about Hilbert spaces. (Technically, Planck did not know about Hilbert spaces either, but he had the right intuition how to perform the sum in a way different from the classical phase-space integral.) One consequence is that the equipartition theorem, according to which each degree of freedom (appearing quadratically in the Hamiltonian) carries average energy ##kT/2##, is valid in classical physics but not in quantum physics.
There is a difference between the Maxwell-Boltzmann distribution (applying to particles with mass) and the more general Boltzmann factor ## e^{-E/kT} ##. The mean energy of a single mode of the radiation field with frequency ## \nu ## can be written as a series of Boltzmann factors: $$
{ h\nu \over e^{h\nu / kT} - 1} = h\nu \left( e^{-h\nu / kT} + e^{-2h\nu / kT} + e^{-3h\nu / kT} + \dots \right) \quad,
$$ so the mean energy is ## kT ## only in the case ## h\nu \ll kT ##.
Planck disliked the idea of quanta. For him the radiation field was continuous and could have any energy, in accordance with Maxwell's theory. He hypothesized that the radiating oscillators could only exchange energy in finite amounts ## h\nu ## with the electromagnetic field, in order to be able to apply Boltzmann's method of calculating entropy (## S = k \ln W ##). As he himself admitted, for him it was an ad hoc idea, introduced in an act of desperation.
I mean exp(-E/kT) is Boltzmann distribution
First, that's not correct, as other posts in this thread have already told you.
Second, that's not the function that Planck used, as other posts in this thread have also already told you.
  • · Replies 0 ·
  • · Replies 26 ·
