Why must Klein-Gordan equation describe spinless particles.
  • Thread starter kof9595995
  • Tags
    Particles
In summary: This is what you need to do to get the sum-of-all-histories interpretation of the propagator, which in turn is what you need to obtain the probability of particle 1 going from x_1 to x_2 while particle 2 goes from x_3 to x_4, etc.
kof9595995
679
It's commonly said K-G equation describes spinless particles, but we know any solution of dirac eqn is a solution of K-G eqn, then can't we say K-G could possibly describe a Dirac spinor field? But if so, it's not spinless any more.
Every component of every (non-interacting) quantum field is a solution of the K-G equation, but only scalar fields represent spin-0 particles. One way to find out what the spin is, is to use Noether's theorem to find the conserved quantities associated with the invariance of the Lagrangian under rotations in space. These will be the three spin operators. (Verify by checking their commutation relations). Now find the eigenvalue of (S1)2+(S2)2+(S3)2, set it equal to s(s+1) and solve for s≥0.
So the saying "K-G equation describes spinless particles" is not accurate?
Right. The K-G equation is satisfied by all (massive) relativistic quanta (and in the massless case reduces to the wave equation.) For spin 1/2 quanta you can "take the square root" of the K-G equation yielding the the Dirac equation.
[EDIT] Actually saying "The K-G equation describes spinless particles" is totally accurate, it just isn't complete. Being described by the K-G equation doesn't imply anything about spin.
Historically, in 1926 about 6 people found the same equation which described a free relativistic particle with mass 'm'. At that time spin of the particle was not an issue. Even as we speak, no matter the spin, the equation has the same structural form: d'Alembertian, mass squared and <wavefunction>.
Later, when the theory of representations of the restricted Lorentz and Poincare groups was built, some spinor indices came on the <wavefunction> [itex] \Psi [/itex] to account for the spin, but both the d'Alembertian and the mass squared remained there.
So the equation has remained since 1926 essentially the same.
P.S. As is assumed in field theory and relativistic QM [itex] c=1 [/itex] and [itex] \hbar =1 [/itex].
I see, so the field equation can hardly characterize the field, instead we need the structure of the field (scalar, spinor, vector...) and how they transform under change of reference frame, to characterize the field, am I right? Then I'm a bit curious, what's the role of field equation in QFT, any comment?
The Lagrangian that the field equation is derived from can be used to explicitly construct an irreducible representation of the Poincaré group, which automatically has the right spin. I think this is done in most QFT books.
Also, I think the Hilbert space of the free theory can be taken to be the set of positive-frequency solutions of the classical field equation. (I probably just left out a bunch of technical details, because I don't have time to think about it now). There's an unpublished set of notes by Robert Geroch titled "Special topics in particle physics" that has some of the details. This is a direct link to the pdf.
The field equation fully characterizes the field. It encompasses both the spin and the mass, which are the 2 Casimir invariants of the Poincare algebra.
The field equation's solutions provide a start of the so-called <canonical quantization> approach. Likewise, the field equations give us the propagator used in the path-integral approach.
How does K-G equation alone characterize the field? Both scalar field and Dirac field satisfy K-G equation.
The correct statement is: The ONE-COMPONENT KG equation describes spinless particles. Higher-spin wave functions have more than one component, even if each of them satisfies the KG equation.
Yeah I agree, but now it's a bit fuzzy to me "what's the role of field equation in QFT"
The Klein-Gordan Hamiltonian is the correct one needed for the partition function in statistical mechanics to describe the Boltzmann statistics of spinless particles. Therefore the Klein-Gordan equation describes spinless particles.
For example, using the Klein-Gordan Hamiltonian for your partition function, you can derive say the pressure of massless spinless particles, and you'll get that it is half that of the pressure from blackbody radiation. This is because massless spin 1 particles have two degrees of freedom due to spin, while spin 0 particles only have 1.
"The field equation" is what you get from the Lagrangian. For the Dirac field, that's the Dirac equation. The field satisfies the field equation. Its components satisfy the Klein-Gordon equation, but since the field components aren't scalar fields, the method I described before won't give you a spin-0 representation.
Hmm, if that's all, it seems field equations do not really play a big role in QFT
Well you solve the field equation to find the Green's function (i.e., free-field propagator) by setting the RHS equal to a delta function.
These form the stems of your Feynman diagrams, and in principle knowledge of these stems, along with an interaction term, gives you scattering. The trick is that using perturbation theory along with Wick's theorem reduces solving interactions into solving for the free-field propagator and multiplying a bunch of them and adding them together.
What's amazing about these Green's functions for the Klein-Gordan propagator is that they propagate backwards and forwards in time, because no matter which direction you close the contour integral (dictated by the sign of t-t' as required by Jordan's lemma), there'll be a pole, so you get:
[tex]
\Delta(x-x')=i\theta(t-t') \int \frac{d^3k}{2(2\pi)^3E_k}e^{ik(x-x')}
+i\theta(t'-t) \int \frac{d^3k}{2(2\pi)^3E_k}e^{-ik(x-x')}
[/tex]
And this shows up in the field equation, and is not just something that comes from QFT.
The field equation is[/i] the (free) dynamics, expressed as a space-time constraint, which also expresses in particular how the system transforms under time translation. It is thus used in QFT to construct the propagator for the quantized fields.
In QFT (and QM in general) we can resolve the dynamics in terms of free propagation and interactions. Free propagation is dictated by the appropriate wave equation and interactions by the gauge field coupling. These are succinctly expressed respectively by Feynman diagram lines and vertices.
Emm, now that Dirac field also satisfy K-G equation, is it possible to write down the propagator of Dirac field from K-G equation?
They do, in the Heisenberg picture.
1. Why can't the Klein-Gordan equation describe particles with spin?
The Klein-Gordan equation is a relativistic wave equation that describes the behavior of spinless particles, meaning particles that do not possess angular momentum. It does not take into account the intrinsic angular momentum, or spin, of particles, which is a fundamental property of particles with mass. Therefore, it cannot accurately describe the behavior of particles with spin.
2. How does the Klein-Gordan equation differ from other wave equations?
The Klein-Gordan equation differs from other wave equations, such as the Schrödinger equation, in that it is a second-order partial differential equation rather than a first-order equation. It also takes into account the relativistic effects of special relativity, whereas other wave equations do not.
3. Can the Klein-Gordan equation be used to describe any type of particle?
No, the Klein-Gordan equation is only applicable to spinless particles. It cannot accurately describe the behavior of particles with spin, such as electrons, protons, and neutrons, which are all fundamental particles with spin.
4. How does the Klein-Gordan equation relate to the Dirac equation?
The Dirac equation is a more general version of the Klein-Gordan equation, as it can describe particles with spin. The Klein-Gordan equation can be derived from the Dirac equation when the spin term is removed. Therefore, the Klein-Gordan equation is a special case of the Dirac equation.
5. Why is the Klein-Gordan equation important in particle physics?
The Klein-Gordan equation is important in particle physics because it was one of the first equations to successfully describe particles with mass and energy. It also laid the foundation for the development of the more comprehensive Dirac equation and other wave equations used in modern particle physics research.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
