Why not calculate the "trajectory" of a wave function
The discussion revolves around the concept of calculating a "trajectory" from a wave function in quantum mechanics, particularly in relation to the Schrödinger equation and classical mechanics. Participants explore the implications of the de Broglie-Bohm theory and the transition from quantum to classical descriptions of particle motion.
  • Some participants propose that the classical limit of the wave function can be expressed as ##\exp{\frac{i}{\hbar}S(x,t)}##, where ##S(x,t)## satisfies the Hamilton-Jacobi equation.
  • Others argue that while de Broglie-Bohm theory provides classical trajectories, it does not fundamentally change the governing role of the wave function.
  • A participant suggests that defining trajectories in quantum mechanics could follow a similar approach to classical mechanics, using boundary conditions derived from the Hamilton-Jacobi equation.
  • Concerns are raised about the usefulness and continuity of the proposed definitions of trajectories, with a participant questioning the validity of certain expressions.
  • Another participant mentions the challenge of determining appropriate initial conditions for calculating wave functions in specific scenarios, such as electrons in atomic or two-slit diffraction contexts.
  • There is a suggestion to explore Bohmian mechanics further, indicating its potential relevance to the discussion.
Participants express differing views on the feasibility and implications of deriving trajectories from wave functions. There is no consensus on the validity of the proposed methods or the nature of the solutions.
Participants note limitations in defining trajectories and the complexity of finding appropriate initial conditions for quantum systems. The discussion highlights the dependence on specific interpretations of quantum mechanics and the challenges in transitioning from quantum to classical frameworks.
This discussion may be of interest to those studying quantum mechanics, particularly in the context of wave functions, trajectories, and interpretations such as de Broglie-Bohm theory.
zhouhao
The classic limit of Schrödinger equation is hamilton-jacobi eqution.
Wave function's classic limit is ##\exp{\frac{i}{\hbar}S(x,t)}##,##S(x,t)## is the action satisfying hamilton-jaccobi eqution.
However, a particle travels along single trajectory of ##S(x,t)##,
Why not make some constrains on wave function to reveal the "single trajectory" from wave function?
That only works in the classical limit, where you can ignore quantum mechanics.
de-Broglie-Bohm has classical trajectories, but everything is governed by the wave function (or pilot wave), so that doesn't really change anything.
Thanks.
How about this way.
Classic Mechanic :
1,wave function (##\hbar \rightarrow 0##) is ##\psi \rightarrow \exp{\frac{i}{\hbar}S(x,t)}##;
2,we get wave function from Hamilton-Jaccobi equation with boundary condition,
##\frac{\partial{S}}{\partial{t}}+\frac{1}{2m}{(\frac{\partial{S}}{\partial{x}})}^2+V(x)=0##;
3,##\frac{dx}{dt}=\frac{1}{m}\frac{\partial{S}}{\partial{x}}## could define a trajectory ##x(t)## for a particle with initial condition ##x(0)=a##;
Quantum mechanic:
1,wave function ##\psi(x,t)##;
2,we calculate ##\psi(x,t)## from Schrödinger eqution, ##-\frac{{\hbar}^2}{2m}\frac{{\partial}^2{\psi}}{\partial{t}^2}+V(x)=i\hbar\frac{\partial{\psi}}{\partial{t}}##;
My textbook stop at second step , just calculate wave function and ignore the third step in classic mechanic which make me confused.
Maybe third step in QM, could be like this -----
-----3,##(\frac{dx}{dt})_n=\frac{(\frac{\hat{p}}{m})^n\psi}{(\frac{\hat{p}}{m})^{(n-1)}\psi}##,##n \ge 1## is an integer.##\hat{p}=-i\hbar\frac{\partial}{\partial{x}}##
When ##\hbar \rightarrow 0## , ##(\frac{dx}{dt})_n \rightarrow \frac{1}{m}\frac{\partial{S}}{\partial{x}}##
This means we define many trajectory for a particle.
You can define a lot of things, that doesn't mean they have to have useful properties. I didn't study your definition in detail, but if in doubt, it won't lead to a continuous trajectory, or even to ill-defined expressions.
zhouhao said:
Thanks.
How about this way.
Classic Mechanic :
Quantum mechanic:
Read about Bohmian mechanics! You can start e.g. from
https://en.wikipedia.org/wiki/De_Broglie–Bohm_theory
Thanks.I think Bohmian mechanics is helpful to me.Could help me with another question below?
##\psi## is a solution of Schrödinger eqution.
When ##\hbar \rightarrow 0##,##{\psi}(x,t) \rightarrow {\rho}(x,t)e^{\frac{i}{\hbar}S(x,t)}##
Define ##\frac{dq}{dt}=\frac{1}{m}\frac{\partial{S}}{\partial{x}}##,
and ##\delta{(x-q(t))}## means choose trajectories beside ##q(t)##,not the real Dirac function.
The ##{\psi}_q \rightarrow \delta{(x-q(t))}e^{\frac{i}{\hbar}S(x,t)}## is a solution.
The linear combination ##{\sum\limits_q}c_q{\psi}_q## is also a solution.
Too many solutions.
If we calculates wave function of electron moving around nuclear or the one of electron in the two-slit diffraction experiment,how to get the initial boundary couditon?Is there any example to calculate this kind of thing?
zhouhao said:
Too many solutions.
There is no simple recipe hot to find the right solutions (right initial conditions). You must study a whole textbook to learn something about it.
  • · Replies 32 ·
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 17 ·
