Cyrus
- Messages
- 3,246
- Reaction score
- 17
SRode said:Some of these postulates are rediculous
How do you figure?
SRode said:Things are engineered in a way for a reason,
You are under the impression that, if tires were solid, they would keep the same geometry. Structurally, I don't think the tire could support itself. It would have to be a much lower profile tire.SRode said:Look at the average sedan tire 205/60/15:
section width 205mm, section height (.6*205) 123mm
Tires are not perfectly cylindrical but you can estimate their volume:
15in = 381mm
(205mm)*pi*((381mm+123mm)^2 - 381mm^2) = .07m^3
A tire is primarily carbon black, synthetic rubber, and natural rubber.
natural rubber has a density of .94 g/cm^3 = 940 kg/m^3
synthetic rubber has a density ~1.2 g/cm^3 = 1200 kg/m^3
Carbon black is just a reinforcement, and becomes neglible when you are talking about filling the entire inner volume with rubber.
You solid rubber car tire (assuming your using the least dense material of natural rubber) now weighs 66kg or 145 lbs.
That is the exact same tire/rim combo I have seen in industry design mags. The rim becomes a compliant part as well as the tire.SRode said:Ah, well then that's a whole different ball game. If you mean somthing like this:
http://www.speedace.info/speedace_images/michelin_tweek_airless_tire.jpg
There was a reason they haven't started producing them yet tho, I think it was that they transfer too much vibrational energy making them noisy.
K.J.Healey said:Just to add my own comments:
1) ... I would assume that for a bike you really don't need THAT much friction to get moving/keep moving/change direction.
3) Weight should not be an issue.
years of terch wnet into the current kelvar belt radial tires we use today..ifin firestone and goodyear thought solid was better it would a happened.
Innomen said:.
Adding a second suspension that takes over the job that the air is doing, is simply adding needelss cost.
They look stupid, but tweels are the future.
but lining up a brand new system, literally reinventing the wheel is an unnecessary expense for a questionalble performance increase.
