Why scientifically, do we need procreation as a species?
  • Thread starter Thread starter Saint
192 replies · 16K views
franznietzsche said:
How does that even make sense? You just put more than a few words in his mouth. he didn't say they were comparable, he said CI has worked perfectly for him. There was no comparison. And of course that works, assuming you know when to interrupt, but it has nothing to do with condoms and their effectiveness.
That's not correct at all, franz. I'm very happy for Les Sleeth that withdrawal has worked perfectly for him, but he is just one data point. Statistically, the withdrawal method is just as lousy a contraceptive as is condom use:
http://www.fda.gov/fdac/features/1997/conceptbl.html
It really doesn't work, because preseminal fluid usually does contain sperm, just not as many as semen. It only takes one.
- Warren
Biology news on Phys.org
Just to stick up (so to speak) for my method, I don't believe it is the minute risk of pregnancy possible from preseminal fluid that drives up the statics for CI, it's individuals not having control. I have advised some couples on this who have told me they went back to other methods because too often the man had slipped "just a bit." I usually suggested two things.
One was to have the man practice feeling the very beginning of ejaculation, practice constricting the same muscle one uses to hold off urinating, and have one's partner learn to be completely still until the feeling passes. After a couple of those events, one can last for hours, and can even learn to keep oneself right on the verge of climax much of the time (that's really fun :smile:).
The other thing I recommended was when one does withdraw, have one's partner take hold! :blushing: (I don't know how else to explain it), and simulate what was going on while inside. That way the man doesn't have to lose the pleasurable sensation of being inside (i.e., and so won't resist pulling out), and one's partner can even learn techniques to make it feel even better!
I hope I've not been too graphic for the kids . . . :cool:
Les Sleeth,
That's all fine and good -- just don't advocate withdrawal as an effective birth control technique, because statistically it isn't, for whatever reason. We surely don't want to be teaching the kids in our audience here that withdrawal is an acceptable method, because it surely is not -- it is not statistically not very effective against pregnancy, and, of course, it leaves the STD door wide open.
- Warren
chroot said:
Les Sleeth,
Okie, dokie . . . I ONLY recommend CI to anyone married to a partner they trust, and to those manly men who can learn to control themselves while in the throes of passion. :smile:
Chroot, there are also risks to IUD use.
Of the two forms of IUD currently available, the ones that contain copper increase menstrual bleeding and is contraindicated for those at risk of iron-deficient anemia or who already have heavy menstrual bleeding. Those that contain synthetic progestins reduce menstrual bleeding, and is actually considered a way to manage excessive bleeding, but is still contraindicated in those who have sensitivities to progestins (which also precludes oral contraceptive use).
The lifetime risk for using IUDs is lower than other forms of contraception, but quite high during the first year of use, when 5-10% of IUDs become displaced or expelled, often without being noticed by the user (especially for displacement without expulsion), which can result in accidental pregnancy (at least when a condom breaks, you know it broke and can seek emergency contraception rapidly).
Also, physicians (at least in the US) will not recommend IUDs to women who are not in a monogamous relationship. Many physicians also will not recommend IUDs to women who have never experienced a pregnancy or younger than 25 (the manufacturers of the Mirena IUD specifically caution against use in women younger than 25). Women who have never had a pregnancy are more likely to have too small of a uterus for the IUD to fit properly in order to avoid expulsion. There is one that has gone through clinical trials abroad, and that has good efficacy and somewhat better safety compared to the "framed" IUDs available in the US, which is a "mini" IUD that is designed for such women, but it is not FDA approved for use in the US; this IUD is of the copper-containing variety. There are also risks of uterine peforations (a severe side effect requiring surgical intervention), that while rare, are nonetheless a major risk if you're the unlucky one.
There are other contraindications to IUD usage, though some of them also ought to be contraindications to intercourse (such as having an STD or AIDS). Others include anything that alters the shape of the uterus or occludes part of the uterine lumen, such as fibroids, which are a very common gynecologic problem.
So while IUDs can be very effective as contraception, there are a lot of women for whom this is not an option.
- Warren
1. If done properly it works, statistically it is done improperly.
2. Now you're doing the same thing to mypost and responding to things that weren't there.
chroot said:
Moonbear,
Condoms are only about 84% effective against pregnancy when used perfectly. Most surveys have indicated that very few people use them anywhere close to perfectly. Their realistic efficacy is probably closer to 70%.
I just want to point out that this contradicts the statistics you posted from the FDA. On their site, with typical (mis)usage, condoms had about a 14% failure rate (so 86% effective), and with completely correct usage, a 3% failure rate (so 97% efficacy). I assume those statistic referred to use of a condom as the sole form of contraception, and not in combination with a second form, which is the only way I would recommend their use as contraception.
You're right to caution that many, possibly most, people do not use condoms correctly.
Have fun shopping at Babies 'R' Us. :smile:
- Warren
I highly doubt that most people notice when the condom breaks. Sure, the massive failures are pretty obvious, but small tears are not.
You mentioned that people should use condoms unless they're trying to procreate with their wife, did you not? I thought we were talking about the use of condoms in long-term monogamous relationships -- something I rail against.
- Warren
Good catch. I have picked up statistics from many places over the years, and drawn my conclusions from them. I will see if I can find the primary sources I considered authoritative in the past.
- Warren
- Warren
That's not what I meant. No wonder you nearly bit my head off! I think I was responding to Saint's questions about teens having sex, though there were so many topics intermingled last night, who knows what I really responded too. I was hardly being serious about my answers last night (at least not in this thread). I think you came in at the end of a very bizarre conversation. Geez, sorry if I confused you about that. :redface: If you're in a long-term, monogamous relationship, I don't give a rat's fiddle what you use as contraception, or even if you use contraception, as long as you and your partner both agree on it and understand the risks.
- Warren
Oooh, I love that store! Baby clothes are soooooo cute! :biggrin:
You are probably right that CI not the best recommendation for mindless climbing on and getting off (double meaning there) sex which seems to characterize how a lot of people have intercourse. But I am quite certain CI is awesomely effective for the CONSCIOUS, conscientous, attentive lover. I mean, at a website dedicated to intelligence, why recommend for the lowest common denominator?
BoulderHead said:
Les, you mean some folks are able to retain consciousness during the rut?!
I just KNEW you were going to say that! :rolleyes:
Saint said:
I know that SEX is NASTY when it is abused.
Oh for goodness sake, it's always nasty! :biggrin:
:smile:
Remember, mocking is immoral!
See, you haven't figured out yet that you can have fun with the silly conditioning that sex is nasty. If you have that trip programmed into you, then make it a fun game with your wife (make sure to talk to her about it first). Pretend you are wickedly enjoying what you aren't supposed to, pretend you are being bad and get off on that, have fun! Sex is nothing on the scale of existence. It means NOTHING. Find a way to enjoy it with your mate, and your marriage will get a lot more interesting overnite.
Do you have statistics to back up this assertion, or are you going to continue talking out your ass?
- Warren
I think sex is just for fun.
"Physics is like sex: sure it has practical reasons, but that's not why we do it."
-Richard Feynman
Also just to note, what Les Sleeth last said is true, but it applies to guys with girlfriends too, or even just sexual friendships.
There was a case here that a woman who sought a doctor to Tighten her vagina, because her husband had lose interest in making love with her due to her vagina is loose after being old and giving birth to several children,
unfortunately, the doctor gave her too much dose of anaesthetic,
she couldn't wake up and died.
SEX can kill a woman, beware!
Yeah, Saint, that happens nearly everyday.
- Warren
I'm sure I've nearly died from sex several times. Where is Humanino? I have heard that in France they colloquially call an orgasm a "little death". Is that true?
I believe one type of Tantric sex involves never ejaculating nor achieving orgasm as a way to awaken consciousness. From what I read, this is a way of preserving the life energy to prolong and heighten the experience.
I don't know if I'm just tired or older or less testosterony than I used to be, but I enjoy making love. I'm not interested in nasty sex, don't want another one night stand. I like falling in and being in love.
But if she doesn't orgasm i can't hear her moaning and screaming my name, and where'sthe fun in that?
I didn't say it was fun :smile: when I was writing that I was thinking more on the male side holding back
