- 150
Here is an animation depicting your scenario:phyti said:Measuring the speed of light involves physics, so it should be possible to explain the results in terms of physical phenomena. We begin in a fixed frame (of reference), aka the universe. It is motionless (unless someone can find a separate entity to serve as a reference for its motion). The propagation pattern of light is spherical from its origin, with a constant propagation speed of c. A simultaneous 360º multi-photon signal from the center of a circular ring will reflect from the ring and return to the center simultaneously. A clock at the center will record 2t units of time for a path length of 2r units of distance. If the ring moves at constant speed v in the x direction, it causes motion induced phenomena in the form of two complementary effects. The em fields of mass modify themselves from spherical to elliptical with an x radius of r'=r/γ, and the clock at the center runs slower than the static clock with 2t'=2t/γ. Both effects are due to the motion extending the distances for light interactions, and are not detectable by the moving viewer. Since the distance and time units are reduced by the same factor γ, r'/t' = r/t = c. The relations for time t and distance x are the same for all inertial frames because of the scaling by 1/ γ. The γ factor is a consequence of constant light speed, therefore the 1st postulate of SR results from the 2nd.
SR is a theory of measurement and perception. Any viewer of the moving ring will see the reflection events occurring over an interval of space and time. Only the viewer moving with the ring will perceive those events as simultaneous, i.e. as if he is in a rest frame. It’s at this point where Einstein knowing you can’t measure light speed relative to the viewer, DEFINES the time out and back as equal, thus supporting the PERCEPTION of the pseudo rest frame.
https://www.youtube.com/watch?v=dEhvU31YaCw
It is explained in great detail in A graphical explanation of Special Relativity.
I'm not sure I agree with all your statements, such as the "em fields of mass modify themselves from spherical to elliptical" because as you can see from the animation, the fields are always spherical in an inertial frame. You also have to be careful about saying "the distance and time units are reduced by the same factor γ" because the time units are increased (dilated) while the distance units are decreased (contracted). It's the Relativity of Simultaneity that "brings" them together so that they "cancel" each other out. Remember, there is no Length Contraction along the directions perpendicular to the motion and yet the Time Dilation still applies. I think the animation makes it very clear.
