Leonardo Muzzi
- 26
- 2
Physically speaking, why the insides of the least massive black hole should be any different from the heaviest possible neutron star?
The discussion revolves around the differences between the interiors of black holes and neutron stars, particularly focusing on the transition from a neutron star to a black hole during stellar collapse. Participants explore theoretical implications, physical properties, and hypothetical scenarios related to this transition.
Participants express differing views on the nature of matter inside black holes compared to neutron stars, with no consensus reached on the specifics of these internal states or the implications of various hypothetical scenarios.
Discussions involve assumptions about stellar collapse, the role of neutron degeneracy pressure, and the implications of general relativity, with some scenarios remaining speculative and not grounded in observable phenomena.
This discussion may be of interest to those exploring astrophysics, particularly the properties of neutron stars and black holes, as well as theoretical physics related to general relativity and stellar evolution.
Neutrons aren't strong enough to support themselves against the pressure.Leonardo Muzzi said:Physically speaking, why the insides of the least massive black hole should be any different from the heaviest possible neutron star?
No.Leonardo Muzzi said:But that is also true for the center of a Neutron start, correct?
A neutron star forms when the inwards pressure from the collapse is not sufficient to overcome the neutron degeneracy pressure, so the collapse stops and we have a core of neutrons. If the collapsing star is more massive the pressure from the collapse will be greater, and if large enough will overcome the neutron degeneracy pressure; the collapse will continue unchecked and instead of getting a core of neutrons we’ll get a black hole singularity.At this point, why would the contents of that black hole be any different from the neutron star that was there right before the event horizon formation?
Nugatory said:No.
RightLeonardo Muzzi said:If neutron degeneracy is not overcomed, black holes can't form?
But isn't that just a hypothetical mathematical model that has no connection to reality? E.G. such a dust cloud could neither form nor remain a cloud if it magically appeared.PAllen said:Most of this discussion is about stellar collapse, and @Nugatory is correct in this context. However, for the general case of black holes in General Relativity, the equation of state doesn't matter when mass is large enough. The classic example is that if you had a dust cloud with the local density of air everywhere, but its size* is that of the Milky Way, it would already be well inside its Schwarzschild Radius.
@Nugatory gave the scenario of a neutron star forming (or not) from a supernova. An additional scenario from the wiki link I gave is of two neutron stars merging. They didn't just form a bigger neutron star like two bubbles merging, but rather the combination was too massive for the neutrons to continue to support themselves and it is believed to have immediately collapsed into a black hole.Leonardo Muzzi said:At this point, why would the contents of that black hole be any different from the neutron star that was there right before the event horizon formation?
The key point is that matter inside BH, for its short period of existence, need not have high density while still being inside the horizon. For example, if a planet entered a supermassive BH, it would be far into its (short) post horizon history before it experienced extreme tidal forces ripping it apart.russ_watters said:But isn't that just a hypothetical mathematical model that has no connection to reality? E.G. such a dust cloud could neither form nor remain a cloud if it magically appeared.
That's a very thought-provoking question. The concept of a black hole came purely from theoretical considerations without regard for the real world, so your question shows real insight. If the neutron star were massive enough and it didn't collapse, you're right, it would form an event horizon external to it's surface and remain undisturbed, invisible to the outside world. The amount of mass it would take for this to happen is somewhere between five and ten solar masses, but alas, as @russ_watters pointed out, the mass limit for the most massive neutron stars is only two to three times the mass of the sun...Leonardo Muzzi said:Physically speaking, why the insides of the least massive black hole should be any different from the heaviest possible neutron star?
Well, you can conceptually posit a giant neutron inside it’s event horizon as a transitory state. But it would not remain undisturbed. At least per classical GR, it would rapidly be compressed and stretched, becoming a singular state very quickly, and as unavoidably as the arrival of tomorrow.alantheastronomer said:That's a very thought-provoking question. The concept of a black hole came purely from theoretical considerations without regard for the real world, so your question shows real insight. If the neutron star were massive enough and it didn't collapse, you're right, it would form an event horizon external to it's surface and remain undisturbed, invisible to the outside world. The amount of mass it would take for this to happen is somewhere between five and ten solar masses, but alas, as @russ_watters pointed out, the mass limit for the most massive neutron stars is only two to three times the mass of the sun...
That is all correct, with a few caveats:Leonardo Muzzi said:Thanks all for the answers, appreciate.
Ok so from what I could understand, it is very well possible that the contents of a black hole are known objects, such as "5 neutron stars moving perfectly in a common center", or a "dust cloud the size of the milky way", although these scenarios will be temporary until these situations collapse. Therefore, there is no strict connection between the formation of a black hole and its contents, at least for a period.
Another conclusion is: whatever formed the black hole, even if a known object like the ones above, eventually will collapse. The result is not known because we don't know what happens with matter when it is put under such gravitational pressure: it is known that it won't be the same as a neutron star, as neutrons can't hold themselver against such pressure.
Are those correct?
PAllen said:That is all correct, with a few caveats:
1) The possibilities mentioned in your first paragraph are possible "in principle" in the same sense as, after a 'break' of the initial triangle on a pool table, having a bunch of people hit all the balls such that the triangle is reformed and cue ejected from it. I gave a more realistic case of a ordinary matter existing within an event horizon as a planet crossing the horizon of a quiescent supermassive BH. This does not require ridiculously improbable initial conditions unlike the other cases I brought up.
2) "eventually will collapse" should better be phrased as "will collapse exceedingly fast".
Good questions!Leonardo Muzzi said:Understood. Thanks.
Ok so exploring this a bit more, taking the scenario where a planet, or a neutron star, enters a black hole... for that brief period before the star's matter gets into the singularity, would this black hole have any characteristics visible outside the event horizon that are any different from another black hole with the same mass, rotation, and angular momentum?
For example, let's say there are detectors all around the black hole that can measure the pull of gravity or the spacetime curvature. For that moment when the start crosses the event horizon, and before it reaches the singularity, would these sensors capture different measures on the side where the star has just crossed the black hole? Even better, would the even horizon itself distorts a bit, given the higher concentration of matter on one side?
PAllen said:Good questions!
There is a theorem: a black hole has no hair. The meaning is that a any black hole settles quickly to a state characterized only by mass, charge, and angular momentum. However, a key word here is settling.
So, a planet falling into a supermassive BH would involve the horizon changing shape as the planet approached, and engulfing it as a bump on the prior horizon shape. Then, there would be what is called “ring down” as the horizon oscillates as it settles to a slightly larger spherical shape. The only way this would be detected from further away would be as gravitational waves. I believe, if you had precise detectors around the BH, that the distribution of gravitational waves would be a anisotropic, especially at first. The anisotropy would be your clue as to where the planet was captured.
Leonardo Muzzi said:let's say we have a neutron start slowly gathering more matter (from any source) over time. At a certain point, this start will become a black hole, that is, an event horizon will form.
PeterDonis said:Because the inside of a black hole is vacuum.
There is an everyday situation that encompasses these boundary types, but with altogether different geometry. Consider a flashbulb going off. Then all events inside the flash propagation sphere up to one hour from the flash, would be such a spacetime region. I think most people would be comfortable talking about the interior of this region.PeterDonis said:Actually, the inside of a black hole is not even an ordinary region of space like you are used to. One of its boundaries, the singularity at ##r = 0##, is not a place in space, it's a moment of time. The other boundary, the event horizon, is an outgoing lightlike surface, which is neither a place in space nor a moment of time.
So asking "what is inside the black hole" is asking a question that already embodies implicit assumptions that are violated inside a black hole.
But a BH formed from collapse would have a matter spacetime regionPeterDonis said:Because the inside of a black hole is vacuum. A black hole is nothing like any ordinary stable object, not even a neutron star.
PAllen said:a BH formed from collapse would have a matter spacetime region
and a vacuum spacetime region inside the horizon
PAllen said:It is also possible for a propelled test body to cross the horizon shortly after the collapsing surface has (or after the horizon has emerged from the collapsing body is more precise), and land on the collapsing surface before the surface reaches the singularity.
I agree with these statements. I don’t think I implied differently.PeterDonis said:Yes, this is true. The matter region is collapsing, so it is still nothing like an ordinary stable object. Also see below.
Yes, but only "shortly" after. Once "shortly" has passed, it is impossible for any object that crosses the horizon to reach the matter region at all. So, except for that short time period, the interior of the hole is vacuum in a practical sense as far as anyone outside it is concerned.
PAllen said:I agree with these statements. I don’t think I implied differently.
