Why the inner product of two orthogonal vectors is zero
The inner product of two orthogonal vectors is always zero due to the definition of the inner product in real vector spaces, specifically R^n. The inner product is calculated as ||a|| * ||b|| * cos(theta), where theta is the angle between the vectors. For orthogonal vectors, cos(theta) equals zero, resulting in a zero inner product. This principle extends to any Euclidean space, as orthogonality implies that the vectors do not extend in each other's directions, confirming that their scalar product, defined as u^t · v, is zero.
  • Understanding of inner product spaces
  • Familiarity with Euclidean geometry
  • Knowledge of vector notation and operations
  • Basic concepts of linear algebra
  • Study the properties of inner products in different vector spaces
  • Explore the implications of orthogonality in higher dimensions
  • Learn about the Gram-Schmidt process for orthogonalization
  • Investigate applications of orthogonal vectors in machine learning algorithms
Students and professionals in mathematics, physics, and engineering, particularly those focusing on linear algebra and vector calculus.
flyerpower
Why is the inner product of two orthogonal vectors always zero?
For example, in the real vector space R^n, the inner product is defined as ||a|| * ||b|| * cos(theta), and if they are orthogonal, cos(theta) is zero.
I can understand that, but how does this extend to any euclidean space?
The inner product is just the amount that one vector extends in the direction of the other - it's how far one arrow "leans over" the other. If they are orthogonal, then they don't lean over each other at all. That's what "orthogonal means - they have zero extent in each other's directions.
This generalizes to many dimensions because each vector defines a direction in that space and the other one may have some lean in that direction.
Algebraically, if u and v are vectors, then their scalar product is defined as u^t \cdot v - in terms of components in an n-D basis that would be:
\left ( u_1,u_2, \ldots ,u_n \right ) \left (<br /> \begin{array}{c}<br /> v_1\\ v_2 \\ \vdots \\ v_n<br /> \end{array}\right )
Try it for any two orthogonal vectors ... it's obvious for any two basis vectors...
\left ( 1,0, \ldots , 0 \right ) \left (<br /> \begin{array}{c}<br /> 0\\ 0 \\ \vdots \\ 1<br /> \end{array}\right )
see?
Thank you, that's the kind of answer i was looking for :)
No worries - I edited to add another kind of answer while you were replying.
  • · Replies 32 ·
