Why the Sign Changes from < 0 to > 0 ?
  • Context: High School
  • Thread starter Thread starter askor
    Sign
The discussion centers on the conditions under which the product of two numbers, represented as \( ab < 0 \), holds true. Specifically, it establishes that for \( ab < 0 \), one number must be positive and the other negative, leading to two cases: \( (1 - \cos(x)) > 0 \) and \( (\cos(x) - \sin(x)) < 0 \). The participants clarify that the product of two negative numbers is positive, and the product of a negative and a positive number is negative. The conversation also touches on the notation used in inequalities, particularly the logical operators "and" (\( \wedge \)) and "or" (\( \vee \)).
  • Understanding of basic algebraic inequalities
  • Familiarity with trigonometric functions such as sine and cosine
  • Knowledge of logical operators in mathematical notation
  • Ability to interpret mathematical expressions and inequalities
  • Study the properties of inequalities in algebra
  • Learn about trigonometric identities and their applications
  • Explore logical operators in mathematical logic
  • Review high school mathematics textbooks for foundational concepts
Students studying algebra and trigonometry, educators teaching mathematical concepts, and anyone interested in understanding inequalities and their implications in mathematics.
askor
Why the sign change from < 0 to > 0?
This just applies the following:
##a>0,b<0\implies ab<0##
Or ##ab<0 \Longrightarrow (a < 0 \wedge b>0) \vee (a>0 \wedge b<0)##
It would have helped if you had told us what the problem was!
IF the problem was to solve the inequality (1- cos(x))(cos(x)- sin(x))&lt; 0 then
either
a) `1- cos(x)&gt; 0 and cos(x)- sin(x)&gt; 0
or
b)cos(x)- sin(x)&gt; 0 and `1- cos(x)&gt; 0.
That is because "positive times positive is positive" and "negative time negative is negative".
But you seem to have left out the second case.
Thank you for all of your answers but I still don't understand. I even can't find it in my algebra textbook. In what book is this kind of inequality is taught?
In high school I learned that the product of two negative numbers is positive. And the product of a negative and a positive number is negative.
In general, these inequalities will be in any high school maths textbook or syllabus.
Why not like this?
##(1 - \text{cos} ~x)(\text{cos} ~x - \text{sin} ~x) < 0##
##(1 - \text{cos} ~x) > 0 ~\vee~ (\text{cos} ~x - \text{sin} ~x) < 0##
askor said:
Why not like this?
OR allows only one to be true, so ##(1 - \text{cos} ~x) > 0 ~\vee~ (\text{cos} ~x - \text{sin} ~x) < 0## is true in case ##(1 - \text{cos} ~x) > 0 ~\wedge~ (\text{cos} ~x - \text{sin} ~x) > 0##, whereas ##(1 - \text{cos} ~x)(\text{cos} ~x - \text{sin} ~x) < 0## is false.
##ab<0## means exactly one factor is negative while the other one has to be positive. OR doesn't not gurantee the second condition.
No, either or both operands can be true. Possibly you're thinking of "exclusive or" (XOR).
Yeah, that was a misleading typeset. I didn't meant the Boolean OR, I wanted to emphasize:
<quote> ab < 0 means a>0 and b<0 </quote> or "[ab<0] allows only one to be true"... followed by the explanation that ab<0 is stronger than the Boolean OR. A bit clumsy I admit.
HallsofIvy said:
either
or
You didn't mean that. Those two cases are the same.
@askor , The product of two numbers is negative only if exactly one of the numbers is negative and the other is positive.
That gives two cases:
a) 1-cos x < 0 and (cos x - sin x) >0 As in your original attachment
or
b) 1-cos x > 0 and (cos x - sin x) < 0
The first case, (a), which was in your attachment, is not possible because 1-cos x < 0 implies that 1 < cos x. That does not happen for any real number, x.
That only leaves the second case (b) as a possibility.
So we can say that 1-cos > 0 and (cos x - sin x)<0
Does above applies too when ab > 0?
What are the conditions on ##a## and ##b## if ##ab > 0##?
I don't know.
askor said:
I don't know.
Well, that's an honest answer. Can you think of a way to find out?
You could multiply some numbers together and note whether the product is positive or negative. Then you could look for a pattern in the cases where the product is positive.
Do you mean if ##ab > 0## then ##(a < 0 \wedge b < 0)## or ##(a > 0 \wedge b > 0)##?
askor said:
Do you mean if ##ab > 0## then ##a < 0 \wedge b < 0## or ##a > 0 \wedge b > 0##?
Personally I'd be happy to say that ##ab > 0## if both ##a## and ##b## are positive or both ##a## and ##b## are negative. Which is what you've written in "wedge" notation.
Do you mean I was correct?
askor said:
Do you mean it was correct?
Yes. But, if you don't understand that notation properly I wouldn't use it.
The "##\wedge##" notation you mentioned about, it mean "and" isn't it?
Yes. And the other one means "or".
Which one is "or"?
askor said:
Which one is "or"?
##\vee##
That's your last question.
What is the name of this inequality?
As far as I know, it's too simple to have a name.
  • · Replies 19 ·
  • · Replies 29 ·
  • · Replies 44 ·
11K
