Undergrad Why to use negative hydrogen in spallation neutron source?
The use of negative hydrogen ions (H-) in spallation neutron sources is preferred over protons due to the ease of creating high-intensity pulses and the requirement for opposite charge during beam injection into circular machines. Utilizing H- allows for the efficient stripping of unwanted electrons, which simplifies the acceleration process. The discussion references CERN's materials for further understanding of the operational advantages of H- ions in high-energy physics applications, particularly in the context of beam dynamics and magnetic field manipulation.
  • Understanding of spallation neutron sources
  • Familiarity with particle acceleration techniques
  • Knowledge of beam dynamics in circular accelerators
  • Basic principles of magnetic field manipulation in particle physics
  • Research the operational principles of spallation neutron sources
  • Study the advantages of using negative hydrogen ions in particle accelerators
  • Learn about kicker magnets and their role in beam injection
  • Explore CERN's resources on high-energy physics and beam dynamics
Physicists, particle accelerator engineers, and researchers involved in high-energy physics and neutron scattering who seek to understand the benefits of using negative hydrogen ions in spallation neutron sources.
kiwaho
Just wondering why to use negative hydrogen H- ion in spallation neutron source.
I read the literature through http://neutrons2.ornl.gov/facilities/SNS/works.shtml , still not yet get the answer.
If directly use proton, then still easy to accelerate, and no need to strip off the unwanted electrons by stopping carbon foil before entering storage ring.
I think there must be a reason to choose expensive H- instead of economy proton.
It makes creating high-intensity pulses easier. CERN has an introduction here and many more references for details.
When you want to move a beam from a linac into a circular machine, you need the injected beam to bend the opposite direction as the circulating beam in order to place the two beams together. If you do this with magnets, that means the linac beam and circulating beam needs to have opposite charge.
It does not need to have opposite charge - you can use kicker magnets, as most accelerators for high-energy physics do.
Those magnets are very fast with their change in magnetic fields, so you can inject particles at one field geometry and then quickly go back to the correct field for circular orbits afterwards (I know you know how they work, that explanation is for other readers).
  • · Replies 28 ·
  • · Replies 16 ·
