stephenx_86
- Messages
- 14
- Reaction score
- 0
Hi,
I'm trying to set up a microscope to have wide-field laser epi-illumination. This is to be used with an infinity-focused objective lens. My current plan has the laser expanded 4x using a Galilean beam expander (from 1mm to 4mm) and coupled into the back of the objective using a dichroic. However, from reading around online I'm a bit confused about a couple of things.
1. I want to have homogeneous illumination across my sample; however, if my logic serves, by shooting the parallel laser light into the back of the objective it will focus down to a spot at the sample. Is this correct? (i.e. will I just get a spot of illumination at the centre of my image?)
2. If I expand the beam sufficiently to fill the back aperture of the objective, will this still be an issue?
2. Alternatively, should I be focussing my laser to the back aperture of the objective? I've seen things that indicate this is the case, but I can't work out if this approach only applies to finite-focus objectives.
Any advice is greatly appreciated.
Thanks
Stephen
Thanks
Stephen
