Understanding the Integration of exp(-t²) with a Change of Variable
  • Context: Undergrad
  • Thread starter Thread starter Heresy42
    Integration
The integral of exp(-t²) over the entire real line is computed correctly as √π using the error function, erf(x). However, when applying the change of variable u = t², the integration limits become problematic since u cannot take negative values. The transformation leads to an incorrect evaluation of the integral, resulting in zero, which highlights the necessity of splitting the integral from -∞ to +∞ into two parts and taking limits appropriately. This discussion emphasizes the importance of understanding variable changes in integration.
  • Understanding of definite integrals and limits
  • Familiarity with the error function (erf)
  • Knowledge of variable substitution in calculus
  • Basic concepts of integration involving improper integrals
  • Study the properties of the error function (erf) in detail
  • Learn about improper integrals and their convergence criteria
  • Explore variable substitution techniques in calculus
  • Investigate the implications of changing integration limits during variable transformations
Students and professionals in mathematics, particularly those studying calculus, as well as educators looking to clarify concepts related to integration and variable substitution.
Heresy42
Dear All,
I computed an integral that looks like erf(x) without problem: \int_{-\infty}^{+\infty} e^{-t^2} dt = \int_{-\infty}^{0} e^{-t^2} dt + \int_{0}^{+\infty} e^{-t^2} dt = \frac{\sqrt{\pi}}{2} [-erf(-\infty)+erf(+\infty)] = \frac{\sqrt{\pi}}{2} [-(-1)+1] = \sqrt{\pi}.
However, what about the change of variable: u = t^2?
Hence: du = 2 dt and: \int_{-\infty}^{+\infty} e^{-t^2} dt = \frac{1}{2} \int_{+\infty}^{+\infty} e^{-u} du = -\frac{1}{2} [e^{-u}]_{+\infty}^{+\infty} = 0.
I just want to be sure: the second integration doesn't make sense, because the lower and upper bounds are the same, right?
Thanks.
Regards.
This is exactly why one splits up an integral from -∞ to ∞ into two parts and takes the limit of each: the normal rules of integration don't necessarily apply.
Hence: du = 2 dt
No
du=2tdt
Indeed, my bad, thanks to both of you.
You've already been told about the problem with du. Another problem here: u cannot be negative, yet you have the integrations limits being -∞ to +∞.
Dear D H,
Thanks for your reply. It's now clear to me that this change of variable is for positive values only.
Regards.
  • · Replies 19 ·
