Will a sliding box fall over when it stops?
37 replies · 8K views · last reply
haruspex said:
How are you defining z here? ##z=A\cos(\phi)## implies you are using it the way I did, but then you should have ##m\ddot x=-\mu N##. x is not z.
Yes, I see that now. I misunderstood the meaning of ##z##. I also understand the re-scaling. I now have to mull over the condition you posted in #30. Thanks.
haruspex said:
Indeed, the conclusion is that tipping will only start/continue if ##\cos(\alpha+2\phi)>\cos(\alpha)/3##, where ##\mu=\tan(\alpha)##.
I do not understand this inequality and how tipping will start/continue if it is satisfied. For ##\phi >\pi/4## the left side is certainly negative while the right side is positive and this will still be so as ##\phi## increases past that point. Isn't ##A## vertical and hence ##\phi=\pi/2## when the CM is at its highest point? What am I missing/misunderstanding?
Ahem.. correcting my algebra..
For the condition for starting/continuing to tip we can take ##\dot\phi=0## and ##\ddot\phi>0##.
Will also assume φ≤π/2, since the development in post 18 might be invalid else.
From the equation in post #18:
##(\frac 13-(\mu\sin(\phi)-\cos(\phi))\cos(\phi))(\mu\sin(\phi)-\cos(\phi))>0##
Writing ##\mu=\tan(\alpha)## we can break this into two cases.
1. ##\mu\sin(\phi)>\cos(\phi)## (i.e. φ+α>π/2)
##\frac 13>(\tan(\alpha)\sin(\phi)-\cos(\phi))\cos(\phi)##
##\frac 23>\tan(\alpha)\sin(2\phi)-1-\cos(2\phi)##
##\frac 53>\tan(\alpha)\sin(2\phi)-\cos(2\phi)##
##5\cos(\alpha)>3(\sin(\alpha)\sin(2\phi)-\cos(\alpha)\cos(2\phi))##
##5\cos(\alpha)+3\cos(\alpha+2\phi)>0##
Looks weird, but..
2. φ+α<π/2
As above but with all inequalities reversed. I'd say the conclusion for this case is it can't happen.
Still looks mighty strange...
I would approach this from an energy viewpoint. First find the center of gravity and weight of the box. Then draw a segment of a circle that the center of gravity followers when the box tips over. Then find the height that the center of gravity has to rise so a tip over is possible. find the energy of the box necessary for a tip over to the energy due to the velocity. Compute the velocity using e = 1/2 m v ^2
Work is not conserved here. For the situation I am trying to analyse, the box is still sliding on one corner. Once it stops sliding, yes energy makes it easy.
Referring to #33, I followed a different route. Starting from
##\ddot\phi(\frac 13-(\mu \sin(\phi)- \cos(\phi))\cos(\phi))=(\mu \sin(\phi)- \cos(\phi))(1-{\dot\phi}^2\sin(\phi)))## and with ##\dot \phi =0##,
I got ##\ddot\phi=\frac{\mu \sin(\phi)- \cos(\phi)}{\frac 13-(\mu \sin(\phi)- \cos(\phi))\cos(\phi)}## which I plotted for two "typical" values of ##\mu## (see below). From the plots it is clear that the condition must be ##\mu \sin(\phi) > \cos(\phi)##. Specifically, additional plots (not shown) indicate that the denominator stays positive for ##\mu## less than about 4/3 which is above what one would expect for blocks sliding on surfaces. So I think that's it.
kuruman said:
I plotted for two "typical" values of μ
Yes, it looks sort of reasonable for those, except why does it peak for μ=1 and φ<π/2?
And it gets really weird for larger μ. Try μ=1.6.
I was incommunicado for several days because of hardware problems. I thought about this some more and here is what I have.
Looks weird, but..
2. φ+α<π/2
Case 1 is always the case if there is to be tipping. Here is the reason. Suppose the block is just sliding with friction but not tipping, like a book sliding across a table on its cover. The torque equation about the CM is ##\mu N h-Ns=0##. Here ##s## is the distance from the point vertically below the CM to the point where the ##N## acts on the block. As ##\mu## increases, ##s## must increase to compensate. However ##s## cannot increase past ##w## the half width of the base. At the threshold, ##\mu N h-Nw=0##. Tipping occurs if ##w## is less that the threshold value, ##w<\mu h##. Let ##\phi_0## be the angle between ##A## and the horizontal. Then ##\cos(\phi_0)=w/A## and ##\sin(\phi_0)=h/A##. The tipping condition becomes ##\cos(\phi_0)<\mu \sin(\phi_0)## or ##\mu \sin(\phi_0)-\cos(\phi_0)>0.## Thus if the condition is satisfied and the block starts tipping, ##\phi## increases and ##\mu \sin(\phi)-\cos(\phi)>0## remains positive since the sine increases and the cosine decreases but remains positive for ##\phi_0<\phi<\pi/2##. Now since the numerator is always positive, one has to ensure that the denominator be also positive.
##\frac 13>\frac{(\sin(\alpha)\sin(\phi)-\cos(\phi)\cos(\alpha))}{cos(\alpha)}\cos(\phi)##
##\cos(\phi+\alpha)\cos(\phi)>-\frac {\cos(\alpha)} {3}.##
