Will My DIY Pipe Shelving Be Stable Enough?
brnlow
I plan on building shelving using 3/4" pipe and fittings. The general design is a 2 shelf system -180 degrees from each other around a center pole at different heights. I plan on bolting the center pole to a plywood base. Each shelf will hold between 5 and 100 lbs. I want to make sure its stable. I think as long as the base extends longer than the shelves on each side I should be ok - am I right. Attached is a basic concept.
  • Side view and top view diagram of a two-shelf pipe stand: a vertical pole on a flat base, with a red shelf near the top on one side and a green shelf lower down on the opposite side.
Yes you are right. You might think about extending the base a bit on the side of the tallest shelf to improve stability against larger disturbances.
Torquil
I'm not convinced- there's no bracing against torsion, for example- either for the pole or the shelves.
