Will the air in the shaft condense?
  • Thread starter Thread starter TSN79
    Air Shaft
The discussion centers on the condensation of air in a vertical shaft containing a Ø160 mm uninsulated steel exhaust duct, with temperatures ranging from +20°C to -10°C. It is established that stagnant air surrounding the duct can lead to condensation of water vapor, particularly at -10°C on the steel surface. The presence of insulation, such as mineral wool, may reduce the likelihood of condensation by minimizing temperature differentials, but insulating only the duct itself is more effective in preventing moisture accumulation.
  • Understanding of thermodynamics related to air temperature and humidity
  • Knowledge of condensation processes in enclosed spaces
  • Familiarity with insulation materials and their thermal properties
  • Basic principles of airflow dynamics in ventilation systems
  • Research the effects of insulation types on condensation prevention in HVAC systems
  • Study the principles of airflow dynamics in vertical shafts
  • Learn about moisture control strategies in building design
  • Investigate the thermal conductivity of mineral wool versus other insulation materials
Building engineers, HVAC professionals, and anyone involved in the design and maintenance of ventilation systems in residential buildings.
TSN79
Consider a small enclosed vertical shaft (say 50x50 cm) inside an aparment building with an Ø160 mm uninsulated steel exhaust duct moving air at anything from +20°C to -10°C depending on time of year. Surrounding areas are at room temperature, 21°C.
The air surrounding the duct inside the shaft will practically be stagnant, and I'm wondering how probable it is that this air will condensate. I'm under the impression that the air needs to have some flow in order to condensate, but I'm not sure if that's at all true. Also, what if the shaft is completely filled with insulation (mineral wool). Will that make a differance?
The air itself won't condense, but water vapour in it certainly will at -10°C at the surface of the steel pipe, unless there is some reason to expect very dry air in the shaft.
There is still some remaining water vapour close to the steel pipe, but the effect might be negligible. Insulating the pipe only could be better.
  • · Replies 28 ·
