- 4,508
Windows creates one and uses it automagically. By default, it resides on the C: drive. Which, even if you have several drives, is the one most heavily used.DrJohn said:As for a swap file - can't remember when I last used one of those.
At least on the older versions of Windows, it was possible to relocate the Swap File to other drives. Then the heaviest usage is still often the C: drive with around 50% - 60% usage, followed by the swap drive.
Also, older versions defaulted to a relatively small swap file which really slowed down the system. This is where I got the most speed-up. IIRC, I had to edit the Registry to increase the file size.
PhotoShop for instance creates its own swap files, but at least gives you the option to specify their locations.
So yeah, moving the swap files to an SSD can speed things up if your disk is slow or fragmented and the memory usage is tight.
Cheers,
Tom
