Wine Fermentation Heat Generation
The discussion focuses on calculating the heat generated during the fermentation process in a winery's HVAC system. Each fermentation tank has a volume of approximately 4000L, with a maximum of 6 tanks fermenting simultaneously. The fermentation temperature ranges from 14-22°C, and the heat produced per fermentation reaction is quantified as -227 kcal, with 15 kcal conserved. The user seeks to determine the total heat generated per liter of alcohol and the necessary cooling capacity for the fermentation process.
  • Understanding of fermentation chemistry and thermodynamics
  • Familiarity with HVAC systems and heat load calculations
  • Knowledge of glucose fermentation and energy production
  • Experience with calculating heat generation in liquid volumes
  • Research "Calculating heat generation in fermentation processes"
  • Learn about "HVAC design for wineries and fermentation cooling"
  • Investigate "Thermodynamics of fermentation and energy yield"
  • Explore "Heat transfer calculations for large fermentation tanks"
Winery engineers, HVAC specialists, and anyone involved in the design and optimization of fermentation processes in winemaking.
Steve Mitchel
I am working on an HVAC system for a winery. Part of the heat loading during the peak late summer/fall season will be from the fermentation process and I am having difficulty finding information on the amount of heat generated from fermentation of wine.
Exposed wine surface area of each tank is 2.63m2.
Total fermenting volume of each tank is approx 4000L of wine before fermentation begins.
Expect maximum 6 tanks fermenting at a time.
Range of fermentation temperatures expected 14-22C.
Can anyone help me with this information and also; is the heat purely sensible or will there be additional latent heat released?
Chemistry news on Phys.org
While I know during winemaking, the fermentation does produce enough heat to require some cooling of the must/wine, I am unsure as too how much heat is produced.
The best source I could find so far is here
Code:
http://tinyurl.com/4g7fxqx
It states on pg 2 that per fermentation reaction, in addition to ethanol and CO2, 2 ATP and heat are produced, the Total free energy change is -227 kcal and the conserved energy is 15 kcal.
If you know the moles of glucose, should be able to figure the total kcal then I would think.
Thanks I think that will work.
Find out how much heat is generated per liter of alcohol (I have used it before, but can't locate it now). In a 4000L tank, about 600L is alcohol, worst case. Now multiple the heat generated per liter by the amount of liters per tank. The shortest fermentation is in the area of 10 days if I recall correctly. So divide that number by 240 to get you capacity required per hour at peak fermentation, then add a percent to account for losses to atmosphere.
  • · Replies 21 ·
28K
