Wording Question Regarding Angles
  • Thread starter Thread starter Linday12
    Angles
The discussion clarifies the interpretation of the phrase "30 degrees to the horizontal." It establishes that this angle is measured from the horizontal plane, confirming that the angle between the object and the horizontal is indeed 30 degrees. The confusion arose from the potential misinterpretation of the phrase, but the consensus is that the measurement is straightforward and does not involve the vertical axis.
  • Understanding of basic geometric concepts
  • Familiarity with angle measurement terminology
  • Knowledge of horizontal and vertical planes
  • Basic trigonometry principles
  • Research the principles of angle measurement in geometry
  • Learn about the relationship between angles and planes
  • Explore common terminology used in geometric discussions
  • Study practical applications of angles in engineering and architecture
This discussion is beneficial for students of geometry, educators teaching angle measurement, and professionals in fields such as engineering and architecture who require a clear understanding of angle definitions and measurements.
Linday12
[SOLVED] Wording Question Regarding Angles
If it says "to the horizontal", such as 30 degrees to the horizontal, would the angle be measured from Y or X? I measured it from the horizontal, but reading it over, it sounds like it's measured towards the horizontal, so I was thinking it may be from the vertical.
Thank you very much!
"30 degrees to the horizontal" means that the angle between the "thing" and the horizontal is 30 degrees.
That's what I initially had, but I always want to read too much into it lol. Thanks for the clarification!
No worries!
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 35 ·
