Work done along the curve in 3 dimensional space
8 replies · 2K views
brkomir
A vector field ##\vec{F}(x,y,z)=(e^y+z^2cosx,xe^y,2zsinx)## is given and a curve ##\Gamma## with parametrization ##\vec{r(t)}=(sin(3t),cost(5+sin(10t)),sint(5+sin(10t)))##. Calculate the work done along the curve ##\Gamma## for ##t\in \left [ 0,2\pi \right ]##
I first checked if ##\vec{F}## is potential:
##rot\vec{F}=\begin{pmatrix}
\frac{\partial }{\partial x} &\frac{\partial }{\partial y} & \frac{\partial }{\partial z}\\
e^y+z^2cosx& xe^y & 2zsinx
\end{pmatrix}=(0,2zcosx-2zcosx,e^y-e^y)=(0,0,0)##
So yes, ##\vec{F}## is potential!
Therefore the work done along the curve ##\Gamma## can be calculated ##\int \vec{F}d\vec{r}=\int grad(u)dr=u(b)-u(a)##
So I somehow have to get the equation of scalar field u...
Since we have a potential field I can say that ##u_x=e^y+z^2cosx##.
That gives me ##u=xe^y+z^2sinx +C(y,z)##
To determine ##C(y,z)## I derive the last equation: ##u_y=xe^y+C_y=xe^y##. The last equality comes from components of vector field ##\vec{F}##.
We can now see, that ##C(y,z)## is actually a function of z only! Let's check:
##u_z=2zsinx+C_z=2zsinx## now we can see that C is not a function of z either, there fore ##C=const## let's set C to 0.
Scala field is than given as ##u(x,y,z)=xe^y+z^2sinx## and the parametrization ##\vec{r(t)}=(sin(3t),cost(5+sin(10t)),sint(5+sin(10t)))## give us
##u(t)=sin(3t)e^{cost(5+sin(10t))}+sin^2(5+sin(10t))^2sin(sin(3t))## but because sin is a periodic function and equal to 0 for ##k2\pi ## where## k\in \mathbb{Z}## the final result is than also zero!
Which can only be explained IF the curve ##\Gamma## is connected.
Is everything written above ok? Is there a way I can check if ##\Gamma## is really connected?
I appreciate all the help!
Cheers
Do you mean
##\vec{r(t)}=(\sin(3t),\cos (t(5+sin(10t))),\sin (t(5+sin(10t))))##?
If so, is it not clear that ##\vec{r(0)}=\vec{r(2\pi)}##?
No. If ##\Gamma## is a closed loop then the work will be zero, but the work could happen to be zero even if ##\Gamma## is not a closed loop.
Try this: dr = (dx, dy, dz). Take the dot product F dot dr and see what you get. (It's going to be an exact differential).
Chet
haruspex said:
Do you mean
If so, is it not clear that ##\vec{r(0)}=\vec{r(2\pi)}##?No. If ##\Gamma## is a closed loop then the work will be zero, but the work could happen to be zero even if ##\Gamma## is not a closed loop.
No, the parametrization is ##\vec{r(t)}=(\sin(3t),(5+sin(10t))\cos t,(5+\sin (10t))\sin t)## .
Aha, ok, I forgot about that. So ##\Gamma## can be a closed loop or it can be anything else, but it just so happens that after ##2\pi## the function is at the same potential as in the beginning.
Chet
##\int \vec{F}d\vec{r}=\int (e^y+z^2\cos x)dx+\int xe^ydy+\int 2z\sin xdz=2xe^y+2z^2\sin x##
Sorry to ask you (i feel so stupid at the moment), but, why is this important?However, we all agree that work done along that curve is 0, right?
I didn't say to write it as an integral. I said to write it as
Fxdx+Fydy+Fzdz=(eydx+xeydy)+(z2cosxdx+2z sinx dz)=d(xey+z2sinx)
And because this is an exact differential, than F is potential?
Sure. More precisely, F is a force described by a potential.
That's what brkomir showed in the first post.
OK, but the question still applies: is it not clear that r(t+2π) = r(t)?
