Work done by a heat engine - quick issue with units used in the solution
The discussion centers on the importance of unit consistency when applying the ideal gas law in thermodynamic calculations. The user correctly calculated the number of moles of oxygen using the ideal gas equation but encountered discrepancies due to the lecturer's use of liters instead of SI units. The user determined that the total work done calculated by the lecturer was excessively high, approximately 15 GJ, due to this unit inconsistency. The consensus is that all measurements must be converted to SI units to ensure accurate results.
  • Understanding of the ideal gas law (pV = nRT)
  • Knowledge of thermodynamic processes and state changes
  • Familiarity with unit conversions, particularly between liters and cubic meters
  • Basic principles of work in thermodynamics, including isothermal processes
  • Study the implications of unit consistency in thermodynamic calculations
  • Learn about the ideal gas law applications in various states and processes
  • Explore the derivation and application of work equations in isothermal processes
  • Review common mistakes in thermodynamic problem-solving related to unit conversions
This discussion is beneficial for students studying thermodynamics, educators teaching gas laws, and professionals in engineering fields who require precise calculations involving gases.
Faloren
"A gas storage system contains oxygen at a pressure of 5 atmospheres at 300 K.
(Here, you may assume that oxygen behaves as an ideal gas.) The volume of the
cylinder is initially 150 L. (State 1.) In a fire the gas is initially heated by 200 K,
with a safety system keeping the pressure constant (state 2). A sprinkler system
then reduces the temperature to 280 K but the volume does not change because the
safety mechanism has jammed (state 3). The gas is then slowly compressed back to
150 L as the safety mechanism unsticks with the temperature staying constant (state
4). Finally, the sprinklers stop and the system warms up at constant volume to
300 K so that it is back in state 1."
(i) Sketch these processes on a pV diagram showing the numerical values of
p, V and T in each of the 4 states. {5}
(ii) What is the net work done by the oxygen? (You may assume that Cp and Cv
are independent of temperature.) {5}
pV=nRT
equations for work with isothermal processes (don't bother with the constant pressure, it's just the area of the rectangle)
i.e W = nRT ln (V2/V1)
Now, I'm happy about the first part (i plotted the diagram correctly). I did forget that i could use the relationships that P1/T1 = P2/T2 etc, but i used the ideal gas equation to work out all the bits individually and they were mostly the same as the answer scheme (only one rounding error - 4.71 calculated against 4.67 exact).
However, the lecturer does some really funny things on his mark scheme. First and foremost, he uses litres in all his volume calculations.
I know all the data from state 1 to work out the number of moles of oxygen in the system, so i said that:
V = 150L = 0.15m^3, P = 5atm = 5*1.01*10^5 Pa, T = 300K given
Plugging this into the ideal gas equation gives just over 30 moles by my calculation. However, when i went back to mark the exam paper with the supplied solutions, i noticed that the lecturer had used litres in almost all his workings - giving far more moles of oxygen than i got (factor of 1000 roughly). This also meant that the total work done by his calculations was something like 15GJ, which seems ludicrously high. It just seems odd that'd he'd make such a "schoolboy" error, so i wondered whether i was at fault. In theory the results should be the same, regardless of what volume measurement you use (and as far as i understand the volume of a litre of substance doesn't depend on the substance!)?
Please note that I'm not concerned with the actual answer, I'm confident that my working is sound even if the numbers are off.
Question: Am i right to say that you must convert to SI units before plugging into the ideal gas equation (i.e. metres rather than litres)?
Yes. Everything must be consistent. If everything else is in SI units, your volume should be in SI units. A litre is a cubic decimetre. So you could use litres IF you converted all of your other units to a system that uses a decimetre as the unit of length. Otherwise, no.
Hah i really hope he didn't mark everyone down last year because of that!
10K
