Work done by force on a non-linear track.
The discussion focuses on calculating the work done by a non-linear force field, represented as f=(4x², 3z-2y, 2z), along a specified curve from point (0,0,0) to (2,1,3). Participants clarify that to compute the work, one must integrate the force along the curve, incorporating the differential of the curve equation, ds/da. The conversation also touches on the concept of conservative forces, concluding that a force can yield the same work on different paths without being conservative.
  • Understanding of vector calculus and line integrals
  • Familiarity with the concept of conservative forces
  • Knowledge of parameterization of curves in three-dimensional space
  • Proficiency in integration techniques, particularly with respect to arc length
  • Study the application of line integrals in vector fields
  • Learn about the conditions for a force to be conservative
  • Explore parameterization techniques for curves in three dimensions
  • Review arc length calculations and their importance in physics
Students and professionals in physics, particularly those studying mechanics and vector calculus, as well as educators looking for insights into teaching non-linear force calculations.
Anza Power
We have a force which changes according to what point you're at, e.g: f=(4x²,3z-2y,2z), we need to calculate the work done by this force from point (0,0,0) to (2,1,3) on different curves
I don't want an answer I just want an explanation for how this is done, this is what I understand so far:
If we want to calculate the curve (a , a²/4 , 3a³/8), aren't we just supposed to put in the equations of the track as x y z in the force equation and do an integral for a from 0 to 2? or do we have to multiply it by the differential of the curve equation? that's the part I'm not getting...
f=(4x²,3z-2y,2z)
f=(4a² , 9a³/8-a²/2, 3a³/4)
I integrated that from a=0 to a=2 but it turned out wrong...
Also, if a force does the same amount of work on two different tracks, does that mean it's conservative for all tracks?
Hi Anza Power! :smile:
The https://www.physicsforums.com/library.php?do=view_item&itemid=75" is ∫ F.ds
Here they've given you a instead of s, so you need ∫ F(a) ds/da da
(ie, ds/da = 1/(da/ds) is the difficult part: you need to find that first … is this a real exam question?)
No, it could just be a coincidence.
However, in this case you could shorten the calculations by seeing that (4x²,-2y,2z) is conservative … you can probably see the potential, so just subtract potentials …
and that only leaves you to calculate the work done by (0,3z,0), which is a lot easier! :wink:
It's a homework question, thanks for the shortening tip, but why would I need s instead of a? aren't they the same?
I've already read that library post but it didn't help much, do you know maybe where I might find some questions with detailed answers of the same type?
Anza Power said:
… why would I need s instead of a? aren't they the same?
nooo … s is arc-lenth, but a can be any old parameter …
for work done, it's essential to use arc-length
see http://en.wikipedia.org/wiki/Arc_length" for some details :wink:
^ Ahaaaaa, now everything finally makes sense, thanks a bunch dude...
