Is the work done by friction on a moving car's wheel positive or negative?
The discussion revolves around the concept of work done by friction on a moving car's wheel, particularly whether it is positive or negative. Participants explore the implications of friction in various scenarios, including the motion of a car and the effects of different frames of reference.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss the direction of friction relative to displacement and question the wording of the original problem. Some provide examples, such as a child sliding to a stop, to illustrate the complexity of work done by friction in different contexts.
The discussion is active, with participants offering various perspectives on the nature of work done by friction. There is acknowledgment of the need for clearer definitions and the role of reference frames in determining the sign of work done. No consensus has been reached, but several productive lines of inquiry are being explored.
Some participants note that the question may be poorly phrased and suggest that additional context, such as the condition of sliding, is necessary for clarity. The concept of "pseudo-work" is also mentioned, indicating a potential area of confusion or further exploration.
songoku
The work done of friction is always:
a. positive
b. negative
c. zero
d. any of these
W = F.d
The answer key is (b) but in my opinion it should be (d) because I think about work done by friction on wheel of car when the car moves. Let say the car moves to the right, then the wheel will rotate clockwise and the direction of friction acting on the wheel by the road will be to the right and since the displacement is also to the right the work done by friction on the wheel is positive.
Am I missing something? Thanks
I agree. And note that the work done by friction can also be zero, e.g. a car parked using its brakes on a hill.
I think the question is badly written and should include a phrase such as “when sliding occurs”. [Edited.]
Even when sliding occurs, the work done by friction on a particular object can be positive.
Take, for example, a child who is running rearward in the aisle on an airliner and who then slides to a stop next to the rear lavatory. The force of kinetic friction from the floor on the child's feet acts forward -- in the direction of the child's net motion, increasing the child's net velocity and ground-relative kinetic energy and doing positive work [in the ground frame]. Both energy and work are frame-relative numbers.
What is true is that if one counts both third law partner forces in the interaction, sliding friction always drains mechanical energy from the system. The net is negative work done. Or zero in the case of static friction. The net work done is an invariant quantity. It does not change depending on the chosen frame of reference.
I think friction's positive work is called pseudo-work, I wonder why.
It all boils down to the force being frame independent but the displacement being frame dependent. There is no such thing as ”work done by friction” without reference to a frame. You can always choose that frame such that the work done by friction is positive, negative, or zero.
Thank you very much for the explanation Steve4Physics, jbriggs444, Delta2, Orodriun, robphy
  • Love
  • · Replies 19 ·
  • · Replies 25 ·
