How Much Work Does Friction Do to Stop a Sliding Ball?
The discussion focuses on calculating the work done by friction on a 1-kg ball sliding down a smooth surface and coming to rest on a rough surface. The potential energy at the height of 8.6 meters is calculated as 84.366 joules using the formula U = mgh. The ball's kinetic energy is derived from the potential energy, and the relationship between kinetic energy and work done by friction is established through the equation dK = μFn d, where μ is the coefficient of friction, Fn is the normal force, and d is the distance traveled on the rough surface.
  • Understanding of potential energy and kinetic energy concepts
  • Familiarity with the work-energy principle
  • Knowledge of friction coefficients and normal force calculations
  • Basic algebra and physics equations related to motion
  • Calculate the coefficient of friction using the work-energy principle
  • Explore the relationship between potential energy and kinetic energy in different scenarios
  • Learn about inclined planes and their effects on motion and energy
  • Study the impact of varying friction coefficients on the stopping distance of objects
Students studying physics, educators teaching mechanics, and anyone interested in understanding the dynamics of motion and friction in real-world applications.
Hughey85
Question:
A 1-kg ball starting at h = 8.6 meters slides down a smooth surface where it encounters a rough surface and is brought to rest at B, a distance 15.8 meters away. To the nearest joule what is the work done by friction?
Can you pls. help with this question? Do you need to find the potential energy and then work from there? potential E = mgy so you could find that... U = (1 kg) * (9.81 m/s) * (8.6 m) = 84.366
but how would I work it from there?
i don't understand is the surface inclined or what
what is the 15.8m supposed to be the horizontal component (if it is inclined plane)?
The surface is a slope that evens out at the end...like a waterslide...by a smooth surface, I believe that means "frictionless"...the 15.8 meters represents the distance when you hit the rough surface to when you stop. The rough surface starts at the "bottom of the slide" and runs along the x-axis.
I hope this isn't confusing, the picture isn't, but I can't seem to copy it over.
from what you just explained
dU = dK from the top of the slide to the bottom all the potential is converted to kinetic energy
mgh = 0.5 m v^2
v1 = root (2gh)
now dK = Mu Fn d
where Mu is the coefficient, Fn is the normal force, and d is the dsitnace it travelled
  • · Replies 33 ·
