Gas Homework: Adiabatic/Isochoric/Isothermal Process
The discussion revolves around a homework problem involving an ideal gas undergoing three thermodynamic processes: adiabatic compression, isochoric cooling, and isothermal expansion. The gas, characterized by a specific heat ratio (gamma) of 1.67, starts at 250 K and 50 kPa in a 26-L volume. The user calculated the work done during each process, finding W_ab = -970 J, W_bc = 0, and W_ca = 901 J, leading to a total work of W = -69 J. The main issue identified was the potential impact of rounding intermediate values on the final answer.
  • Understanding of the ideal gas law (pV = nRT)
  • Familiarity with thermodynamic processes: adiabatic, isochoric, and isothermal
  • Knowledge of work calculations in thermodynamics (W = PΔV)
  • Concept of specific heat ratio (gamma) in thermodynamics
  • Review the derivation and application of the adiabatic process equations
  • Study the implications of rounding in thermodynamic calculations
  • Learn about the significance of the specific heat ratio (gamma) in different gases
  • Explore detailed examples of isothermal processes and their work calculations
Students studying thermodynamics, particularly those tackling ideal gas problems, as well as educators looking for examples of common pitfalls in thermodynamic calculations.
MeliMo
A 26-L sample of an ideal gas with (gamma)= 1.67 is at 250 K and 50 kPa . The gas is compressed adiabatically until its pressure triples, then cooled at constant volume back to 250 K, and finally allowed to expand isothermally to its original state.
I've called the three states a,b, and c, so the subscripts are W_(from-to)
W_ab= (P_a*V_a - P_b*V_b)/(gamma-1)
P_b=(50 kPa)(3)=150 kPa
P_a(V_a)^gamma=P_b(V_b)^gamma
W_bc= 0
W_ca= nRT*ln(V_a/V_c)
pV=nRT
V_c=V_b
The first process is adiabatic, so I used the first equation to find the work. I first needed to find the V_b, so I used the second equation: (50 kPa)(26 L)^1.67=(150 kPa)(V_b)^1.67
I found that V_b= 13 L (based on another part of the question that I solved correctly I know that they rounded it to 13).
Then W_ab= [(50)(26 )-(150)(13)]/(1.67-1) = -970 J
The second process was isochoric, so W= 0.
The third process is isothermal, so I used:
W_ca= p_a(V_a)ln(V_a/V_c) = (50)(26) * ln (26/13) = 901 J
So then the total work done is: W= 901-970 = -69 J
can someone please tell me where my mistake is? Thanks!
Check the sign. Since this is work done on the system.
Edit: I did remove the part about kPa * L = J when I quickly realized I was wrong.
Actually kPa * L = J is true...
It seems like your math is correct, but I wonder about the rounding. You're not supposed to round intermediate values like the 13L; rounding is only applied when you write out the final answer. In this case, the difference between 13L and the unrounded value is large enough that it makes a noticeable (well, more than just "noticeable") difference in the answer.
Yeah, I tried answering with both the rounded and not rounded intermediate and I noticed the difference too, but it still returned both answers as incorrect. Usually when just the sign is wrong it'll say so as well... I've been going off of an example in my book that is pretty much the same problem with different values and somehow I keep getting it wrong. In any case its good to know that its not just me making some very obvious mistake, thanks!
10K
