Work done to bring together 2 protons
The discussion focuses on calculating the work required to bring two protons from an infinite distance to a separation of 1.0 femtometer (fm). The relevant equations include Coulomb's law, F = k|q1||q2|/r², and the work-energy principle, W = F*r. The potential energy of the system is given by U = kq1q2/r, where U is positive due to the repulsive force between protons. It is established that the work done by an external agent is positive, as the protons repel each other, necessitating positive work to bring them closer together.
  • Understanding of Coulomb's law and electric forces
  • Knowledge of potential energy in electrostatics
  • Basic calculus for integration of force
  • Familiarity with the concept of work in physics
  • Study the derivation of electric potential energy formulas
  • Learn about the integration of force over distance in physics
  • Explore the implications of electric fields on charged particles
  • Investigate the relationship between work and energy in conservative forces
Students studying electromagnetism, physicists interested in nuclear forces, and educators teaching concepts of work and energy in electrostatics.
crazuiee
The nucleus of a Helium atom contains 2 protons which are 1.0fm apart. How much work has to be done by an external agent to bring the two protons from an infinite separation to a distance of 1.0fm.
F=k|q1||q2|/r^2
W=F*r
Would i just need to use the charge of a proton to find the force? and then plug it into the work equation?
The force varies with r, so what force value would you use? You can't even get away with an average value because of the squaring. If you know calculus you can do the integral of F*dr. If not, you'll have to look up a formula for the electric potential energy of a charge at distance r from another charge.
Would I set the potential energy to the work
and solve for electrical potential energy
so U=-W
U=kq1q2/r
Yes, that's all you need. U = 0 at infinite distance, so all the work done becomes the U at r = 1 fm.
so U=-W
U=kq1q2/r
Yes, this is somewhat correct. Since there are two protons in your system, U > 0. But your previous equation suggests that the external agent must do negative work, which isn't quite correct b/c protons repulse each other and it should be harder (positive work) to bring them close together. Therefore, your equation U = -W is actually the work done by the electric field. The applied work W_app is W_app = -W = U, so W_app > 0 for this problem.
  • · Replies 28 ·
9K
