How Do You Calculate Energy and Speed on a Roller Coaster?
The discussion focuses on calculating kinetic and potential energy for a roller coaster scenario involving a mass of 56.2 kg at a height of 19.5 m and a speed of 12.8 m/s. The relevant equations used are potential energy (PE = mgh) and kinetic energy (KE = 0.5 * mv²). The calculated values are: kinetic energy at the top of the loop is 4.60 x 10³ J, potential energy is 1.07 x 10⁴ J, total mechanical energy at the bottom is 1.53 x 10⁴ J, and the speed at the bottom of the loop is 23.4 m/s. The discussion emphasizes the conservation of energy principle in determining these values.
  • Understanding of basic physics concepts: kinetic energy and potential energy
  • Familiarity with the equations PE = mgh and KE = 0.5 * mv²
  • Knowledge of the conservation of energy principle
  • Ability to perform algebraic manipulations and unit conversions
  • Study the principles of energy conservation in mechanical systems
  • Learn how to apply the equations of motion in physics problems
  • Explore real-world applications of kinetic and potential energy in roller coasters
  • Investigate the effects of friction and air resistance on energy calculations
Students studying physics, educators teaching energy concepts, and anyone interested in understanding the mechanics of roller coasters and energy transformations.
alijan kk
Ima Scaarred (m=56.2 kg) is traveling at a speed of 12.8 m/s at the top of a 19.5-m high roller coaster loop.
a. Determine Ima's kinetic energy at the top of the loop.
b. Determine Ima's potential energy at the top of the loop.
c. Assuming negligible losses of energy due to friction and air resistance, determine Ima's total mechanical energy at the bottom of the loop (h=0 m).
d. Determine Ima's speed at the bottom of the loop.[/B]
PE=MGH
KE=0.5*MV^2[/B]
i tried to find b
pe=0.5*56.2*12.8
=14,027.52help me understanding the question.
the answers are.
  • Show Answer
a. 4.60 x 103 J
b. 1.07 x 104 J
c. 1.53 x 104 J
d. 23.4 m/s
alijan kk said:
i tried to find b
pe=0.5*56.2*12.8
=14,027.52
Looks like you've mixed your two relevant equations together.
your relevant equation says pe = mgh, but that's not what you've done, what is m? g? h?
First identify all your variables so you know where they'll go in your equations.
Also, your arithmetic is wrong, 0.5*56.2*12.8 does not equal 14,027.52
Show your units with your working, and be specific on exactly where you're stuck/ what you don't understand, it makes it easier to help.
PE= mass*gravity*height
i want to imagine the picture of that question so that it would be easy for me , i want to understand the question
sorry the answer of pe=0.5*56.2*12.8
is 359.68
but it is also wrong...
is there any role of friction?
or use of this formula
Pi+Ki=Pf+Pi
All the ANswers i have got! thank you bilijoule i was making big mistake,,,,
Great, good work.
billy_joule said:
Great, good work.
thankyou\
but i m still trying to find the speed at the bottom of the loop .
KE=KE
4600=0.5*56.2*v^2
4600=28.1*v^2
4600/28.1=v^2
v^2=163.7
square root both sides
v=12.8
so this way i got the initial velocity but how to get the speed at the bottom?
When Ima gets to the bottom, the potential energy she had at the top has been converted to kinetic energy via Conservation of Energy.
This should be somewhat intuitive, ever ridden your bike down a hill? You don't even need to pedal to gain kinetic energy..it's coming from somewhere else..
The higher the hill the faster you'll be going at the bottom...
The relevant equation:
EKi + EPi = EKf + EPf
(which is what I think your earlier equation in post #4 was supposed to be?
Pi+Ki=Pf+Pi
Solving for EKf is the answer to c), then solving EKf = 1/2 mv2 for v will give the answer to d)
v=23 m/s ! thanks for the equation .
KEf=1/2mv^
  • · Replies 21 ·
