Work Energy Equation Help (what size shock absorber to use)
The discussion revolves around determining the appropriate size of a shock absorber for a seat that supports a person's weight, particularly in the context of damping motion from bumpy surfaces. Participants explore the relationship between the shock absorber, spring dynamics, and the forces experienced by the rider.
  • One participant questions whether the force output of the motor/drive can simply be calculated as the weight multiplied by 9.81, suggesting that the situation may be more complex.
  • Another participant notes that the spring component, rather than the shock absorber, primarily supports the weight, and emphasizes the importance of understanding the energy dissipation characteristics of the shock absorber based on the vibration patterns.
  • A participant clarifies that the shock absorber will be mounted to the seat and connects it to a base, and inquires if knowing the weight and G force can help estimate the required size of the shock absorber.
  • Discussion includes the relationship between the spring rate, deflection, and the forces experienced by the rider, highlighting how the shock absorber and spring work together to manage impact energy.
  • One participant proposes that if the shock absorber dampens a certain amount of energy, the remaining energy is absorbed by the spring, suggesting that adding more springs could allow for a smaller damper.
  • Another participant confirms that springs store energy and can cause a rebound effect if not properly damped, explaining the function of automotive shock absorbers in managing this rebound.
  • A participant shares a link to a resource on damped systems, indicating a potential reference for further understanding.
  • One participant mentions a previous calculation related to spring/shock absorber design for kayaks, offering insights into energy absorption and damping requirements.
Participants express various viewpoints regarding the dynamics of the shock absorber and spring system, with no clear consensus on the best approach or calculations needed to determine the appropriate shock absorber size.
Participants acknowledge the complexity of the problem, including the need for specific data on motion and energy inputs, as well as the interactions between multiple springs and dampers.
Mechaman
Hi everyone. I'm trying to work out what size shock absorber to use. It's going under a seat so just the weight of a man really that it has to support.
I've found a website showing the equations I need but I'm not sure about one of the steps. In step 2 it asks force output of the motor/drive. For my problem would this just be the weight x 9.81?
Here is pic from website: http://imgur.com/a/expcS
Any help would be much appreciated!
I suspect it's way more complicated.
Presumably your shock absorber is intended to damp out motion caused by a bumpy road or similar?
Firstly it's the spring part not the shock absorber part that supports the weight.
Shock absorbers must be able to dissipate the energy they absorb. The amount of energy they must absorb depends on the vibration pattern (eg Large fast transients puts more energy into the shock absorber than short slow transients. I think you can only answer the question with data on the motion of the floor of the vehicle eg bottom end of the shock.
I should clarify that the seat is attached to a base by a sort of leaf suspension set up. The shock absorber (with its own spring as well) will be mounted to the seat, connecting the seat to the base.
If I know the weight of the person and I know the G force subjected to them, should I not be able to estimate how big a shock absorber I would need to lessen the impact?
The force that will be experienced by the rider is a function of the spring rate and deflection of the seat spring vs. the input energy. Without a shock absorber the rider experiences very little force (beyond that of his own weight) at the beginning of the impact that increases to a peak value at the point at which the spring stored energy is equal to energy input to the seat spring assembly.
The shock absorber reduces the peak force at the end of the spring travel by increasing the force the rider experiences at the start of impact, absorbing energy throughout it travel and thereby reducing the amount of energy the spring must absorb and it maximum travel and force.
As a result, the spring and shock absorber act in concert to absorb the impact energy and determine the maximum G force the rider will experience.
Thanks for the explanation. Does that mean that I can take the amount of energy the shock absorber dampens and the remainder is in the spring surrounding the shock absorber? Hence, if i had a second or third spring under the seat, my damper could be even smaller each time I add a spring?
Also does this mean that the springs have stored energy so they have a tendency to spring back up where as the damper dissapaits the energy. Would the springs want to throw the person off if they outnumber the damper in terms of energy?
In response to your question regarding the rebound of the springs stored energy, Yes, if the springs return is not damped then that is exactly what will happen. That is the reason that automotive shock absorbers are "double acting" (damp on both their compression and extension strokes) but not necessarily at the same amount by having separate internal valving and orifices for each direction.
See the attached excel calculation that I performed for an earlier thread about the design of combined spring/shock absorber seat cushioning for kayaks. In your case the Kayak's contribution due its submersion as it impacts the water is set to zero. It will allow you to determine the amount of energy the shock absorber will have to absorb for a given input energy and spring selection.
PS In that case it was shown that the planned design damping system for its application was not practical.
  • · Replies 19 ·
  • · Replies 17 ·
12K
  • · Replies 26 ·
