Work energy theorem and gravitational potential energy
The discussion centers on the work-energy theorem and its relationship with conservative forces, particularly gravitational potential energy. It establishes that when only conservative forces, such as gravity, are acting, the work done (Wnet) equals the change in kinetic energy (KEfinal - KEinitial). The conversation also clarifies that non-conservative forces, like friction, disrupt energy conservation, leading to energy losses that cannot be accounted for by potential energy changes. The conservation of mechanical energy holds true only in the absence of non-conservative forces.
  • Understanding of the work-energy theorem
  • Knowledge of conservative and non-conservative forces
  • Familiarity with gravitational potential energy concepts
  • Basic principles of kinetic energy
  • Study the implications of non-conservative forces on energy conservation
  • Explore the mathematical derivation of the conservation of mechanical energy equation
  • Investigate real-world applications of the work-energy theorem in physics problems
  • Learn about energy transformations in closed and open systems
Students of physics, educators teaching mechanics, and anyone interested in understanding energy conservation principles in physical systems.
Miike012
In my book it is talking about conservation forces and work energy theorem.
In the book it said...
"suppose gravitational potential energy alone does work (constant force)
*Then Wnet = Wg ... ending statement Ef = Ei...
My question... Does the work energy theorem only deal with conservation forces? Because why would they say if this is the only force (being a conservation force) then it equals Wnet...?
On the contrary, the work-energy theorem states that
Wnet = Wc +Wnc = KEfinal - KEinitial
If gravity alone is the only force doing work, then Wnc = 0, and the equation for that special case boils down to
Wnet = Wg = KEfinal - KEinitial. Watch signage.
thank you,.
Another Question:
Correct me if I am wrong... conservation of energy states that energy of a system is conserved.. thus the gain i Kinetic energy is equal to the loss in potential energy of all the forces acting on the body...
Question... in general non conservation forces ( like friction ) cause a non constant kinetic energy, and this loss or gain in Kinetic energy can not be gained by non conservation forces as potential energy because potential energy is not associated with non conservation forces.. thus energy through out the system is not conserved... Is this a correct statement?
Thank you.
Assuming there are no other sources of loss (e.g. sound, temperature change, etc.) which is an idealized but very common situation when working out problems. If we are using your initial problem where only gravitational potential is concerned, then yes, what you gain in kinetic as you fall will be reflected in an equal loss of gravtiational potential (reflected in the change of height).
For question two, there are other ways you can gain energy, as I've mentioned above. Heat, sound, etc. But no, conservation of energy for the system does not strictly apply in this sense, because there are losses from system to surroundings due to friction and other possible changes.
Energy can neither be created nor destroyed, only transformed to different types of energy.
Since Wnc = ΔKE + ΔPE, then when only conservative forces, such as gravity and ideal springs, do work,
Wnc = 0, and therefore,
ΔKE + ΔPE = 0.
This is the conservation of mechanical energy equation, which, when only conservative forces act and there are no non-conservative forces acting that do work, tells us that in such a system the energy is always constant...it is neither lost nor gained, but transformed from one type to the other, whether the system is isolated (a closed system) from its surroundings or an open system (un-isolated from its surroundings).
When non-conservative forces, like friction or applied forces, act and do work, then the change in mechanical energy is not 0, and energy is apparently lost or gained to or from its surroundings (open system). It should follow, therefore, knowing that energy cannot be destroyed, that the work done by nonconservative forces can be represented as
-ΔE0, where ΔE0 is the other energy (heat, sound, chemical, etc.) transferred out of or into the system. This can be also looked at as a closed system, where
ΔKE + ΔPE + ΔE0 = 0,
the total conservation of energy equation, where again energy of a system is always a constant, but transformed to different forms.
  • · Replies 58 ·
  • · Replies 43 ·
