Work Energy Theorem in Moving reference frames
The Work Energy Theorem states that the net work done on an object equals its change in kinetic energy, applicable in any frame where Newton's laws hold. When analyzing motion from a moving reference frame, both kinetic energy and work terms must account for relative velocities, and the theorem remains valid with appropriate adjustments for fictitious forces in accelerated frames. Heat energy terms, often arising from friction, do not appear in the basic work-energy equation derived from Newton's laws but can be incorporated when considering energy conservation. The relationship between work, kinetic energy, and heat can be mathematically derived, showing how these concepts interconnect. Understanding these dynamics enhances the application of the Work Energy Theorem across different reference frames.
rushil
This is a highly theoretical question... so beware!
The Work Energy(WE) equation in Mechanics says that the net total work done on an object due to various conservative and non-conservative forces equals the change in kinetic energy of the body. This above theorem is usually derived simply from Newton's laws in the EARTH Frame. Now, consider a variant ( actually a no. of variants! :smile: ) :-
1) Consider the analysis of motion of the body in the frame which is moving with a constant velocity \vec{u} in the Earth frame. Now, what does the Work Energy equation look like when a person in THIS frame tries to analyse the motion of the body? i.e. does the KE term include relative velocities and even the Works done change etc... basically, please derive the final, exact Work Energy equation in this frame... is it possible to apply WE theorem in this frame?
2) I ask the exact same question as above when the frame of reference is moving with an acceleration ( uniform or even time varying!) \vec{a} wrt the EARTH??
3) Now, let's come back to the EARTH Frame. The work done , when derived using Newton's equations DOES NOT contain terms for heat energy exchanged etc. Where do these come from when we consider the Law of conservation of energy? Do Heat related terms appear in the work energy equation?
4) Finally, I ask the same question as (3) above when our frame of reference is moving relative to the Earth with a constant velocity or some acceleration?? What happens to the 'Heat' terms now?
Basically, my last two questions ask this :- Do heat exchange terms come in the WE theorem as derived from Newton's 2nd law? How do we correlate the WE eqn and the First Law of Thermodynamics? Why doesn't heat appear as the 'work of some force'? If it does, which force is it?
I shall strongly prefer suggestions to this problem that have a proper mathematical basis and are derived rigorously! :approve:
There is nothing terribly profound about the work energy theorem which simply states that the total work done on a particle during a certain interval is equal to the change in the particle's kinetic energy over that interval. This theorem is valid in any frame where Newton's Second Law (from which it is derived) is valid. The work and the change in kinetic energy may be different in different frames, but they are always related by the work energy theorem. The situation can be extended to include frames in uniform accelerated motion by adding the usual fictitious force to Newton's Second Law. "Heat terms" typically correspond to the work done by friction forces, for example.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 25 ·
  • · Replies 18 ·
  • · Replies 33 ·
