Empty Tank: Work Calculation w/ Origin at Apex of Cone
  • Thread starter Thread starter songoku
    Empty Tank Work
The discussion centers on calculating the work required to empty a conical tank by pumping water to the top, with the origin set at the apex of the cone. The correct approach involves using the similarity of triangles to establish the relationship between the radius and height of the water, leading to the integral for work: $$W=\int_{2}^{10} \rho . \pi \frac{4}{25}y^2. g (10-y) ~dy$$. Participants highlight the importance of correctly identifying the limits of integration, which should reflect the actual height of the water in the tank, and emphasize the need for visual aids, such as sketches, to clarify the problem.
  • Understanding of calculus, specifically integration techniques.
  • Familiarity with the concepts of work and energy in physics.
  • Knowledge of conic sections and geometric properties of cones.
  • Ability to apply the principles of fluid mechanics, particularly in relation to pressure and volume.
  • Study the principles of fluid mechanics, focusing on hydrostatic pressure and work done by pumps.
  • Learn about the application of integration in calculating volumes and work in conical shapes.
  • Explore the use of visual aids in solving calculus problems, including sketching geometric figures.
  • Investigate the differences in calculus textbooks, particularly the evolution of teaching methods in "Thomas" calculus editions.
Students of calculus, physics educators, and engineers involved in fluid dynamics or tank design will benefit from this discussion, as it addresses common misconceptions and emphasizes the importance of accurate problem representation.
songoku
A tank has the shape of an inverted circular cone with height 10 m and base radius 4 m. It is filled with water to a height of 8 m. Find the work required to empty the tank by pumping all of the water to the top of the tank. (The density of water is 1000 kg/m^3)
W = ##\int F dx##
I take the origin to be at the apex of the cone. Using the similarity of the triangle, where ##r## is radius of water and ##y## is height of water from the apex of cone:
$$\frac{r}{y}=\frac{4}{10}$$
$$r=\frac{2}{5}y$$
The mass of water = ##\rho .V## = ##\rho . \pi r^2~\Delta y## = ##\rho . \pi \frac{4}{25}y^2~\Delta y##
The weight of water = ##\rho . \pi \frac{4}{25}y^2~\Delta y. g##
The distance needed to move the water to the top of the tank = 10 - y
The work needed:
But I got wrong answer and the teacher said my origin was wrong. I still don't understand why I can't take origin to be at the apex.
Thanks
Perhaps the issue is that you have not considered the surface of the water to be 8 m above the floor or bottom of the tank and 2 m below the apex?
I find this statement a little confusing: “empty the tank by pumping all of the water to the top of the tank.”
That is what seems strange to me, not the choice of origin.... :wink:
If the apex is at the bottom, then the fluid occupies the region 0 \leq y \leq 8, not the region 2 \leq y \leq 10. If the apex is at the top, then the distance required to lift the fluid to the top of the tank is y, not 10 - y.
So what's an inverted cone in the mind of the exercise composer ....
Since only the 4 m base radius is given , we may conclude that the top radius is 0 m and that some mind reading is required for this exercise :smile:
Likes Lnewqban and songoku
Here is my interpretation, but I see your point. :wink:
$$W_p = \int \Delta P ~dV\llap{-}$$
The change in pressure across the pump:
$$ \Delta P = \rho g ( 10 - y )$$
The differential volume:
$$ dV\llap{-} = \pi r^2 dy = \pi \left( \frac{2}{5} \right)^2 y^2 dy $$
$$ W_p = \pi \rho g \left( \frac{2}{5} \right)^2 \int_{8}^{0} (10-y) y^2 dy $$
So as others have pointed out it stems from your limits of integration.
Ah, the limit of integration should be the region the fluid occupies. I thought it should be the distance moved by the fluids.
Thank you for the help and explanation Lnewqban, BvU, pasmith, erobz
Likes Lnewqban and erobz
Another way to see it is the work or energy needed to move the whole mass of fluid between the height of its center of mass (full tank) and the height of the top of the tank.
Likes mathwonk, erobz and songoku
and if all is well, that should yield the same integral ...
"Another way to see it is the work or energy needed to move the whole mass of fluid between the height of its center of mass (full tank) and the height of the top of the tank."
One reason I criticize recent "Thomas" calculus books, is to note that this simple and powerful principle is given in early editions of Thomas Calculus, (those written by Thomas himself), but not in later ones.
@songoku, I'm hoping that you drew a sketch of the tank with the water level shown, similar to the one that @erobz provided. A cross-section of the tank would be sufficient. If you did draw such a sketch, you might have realized that the typical volume elements extend only between y = 0 and y = 8. Each layer has to be lifted from its position in the tank to a point 10 units above the bottom the tank.
In my experience teaching calculus for many years, I've found that very many students resist drawing a picture, thinking (mistakenly) that it will take too much time. It's better to take 3 minutes longer to get the right answer, than to skip this step and get the wrong answer.
Likes BvU, songoku, Lnewqban and 1 other person
