Working Examples RLC Circuit with 5V Ramp Voltage Laplace Transforms
8 replies · 3K views
Cooler
can anyone give me the working examples of current expressions of series RLC circuit using ramp voltage by Laplace transforms. thanks
R=15, L= 0.4H, C=12uF ...voltage 5v
You write a conservation of voltage around the loop:
[tex]-v(t) + Ri(t) + L\frac{di}{dt} + \frac{1}{c} \int i(t) \, dt=0[/tex]
Take the Laplace of both sides:
[tex]-V(s) + R I(s) + LsI(s) + \frac{1}{cs}I(s)= 0[/tex]
Solve for your sought after function of current:
[tex]I(s) = \frac{V(s)}{R + Ls + \frac{1}{cs}}[/tex]
Remember, this solution assumes initial conditions equal to zero.
i stuck on the 1/s^2 [r + sL + 1/sC] ...do we need multiply all inside the bracket by s^2?
Yes. Then you will most likely need to do fraction decomposition. The trick will be putting the answer in a form present in your Laplace tables.
i don't get the fraction decomposition...
when i multiplied inside the bracket it gives me...(15s^2 + 0.4s^3 + 83.333x10^3 s) is this correct and what to do next?
[tex]I(s) = \frac{1}{s(Ls^2 + Rs + \frac{1}{c})}=-\frac{c^2(R+sL)}{cLs^2+cRs+1}+\frac{c}{s}[/tex]
sorry i don't get the idea of how it end up that way...mind to explain? thnks
Have you googled for tutorials yet? Google "fraction decomposition" or "partial fraction decomposition"
http://www.purplemath.com/modules/partfrac.htm
Essentially, it is a procedure for reversing the addition of two fractions.
so you can say a/b + c/d = (ad + bc)/(bd)
but in partial, you start with the right hand side and find the left hand side.Effectively (though it's not the complete picture), b = s and d = (ls^2 + rs + 1/c). And the reason I chose to only distribute 1 of the s in s^2 is that 1/s and 1/(as^2+bs+c) are usually in Laplace tables.
What answer did you get?
my answer is 7.5x10^-4[ 1 - e^-18.75t(cos 456.05t + 41.11x10^-3 sin 456.05t)
