Working out steam velocity with only pressure difference
The discussion focuses on calculating steam velocity in a turbine transitioning from a pressure of 6 MPa to 0.008 MPa. It emphasizes that the steam velocity is influenced by the internal resistance caused by turbine blades and rotors. A theoretical maximum velocity can be estimated by treating the system as having no resistance to flow, considering the change in pressure and specific volume at each cross-section. The conditions of steam can vary from superheated at the turbine inlet to sub-cooled condensate at the outlet.
  • Understanding of steam properties, including superheated and sub-cooled states.
  • Knowledge of thermodynamics, specifically adiabatic processes.
  • Familiarity with steam turbine mechanics and energy transfer principles.
  • Basic principles of fluid dynamics, particularly regarding pressure differentials.
  • Research the calculation of steam velocity using Bernoulli's equation in fluid dynamics.
  • Study the principles of adiabatic expansion and its effects on steam velocity.
  • Explore the impact of turbine blade design on steam flow and energy extraction.
  • Learn about the specific volume of steam and its role in thermodynamic calculations.
Engineers, thermodynamic specialists, and students studying nuclear power systems or steam turbine design will benefit from this discussion.
jacob1
Thread moved from the technical forums to the schoolwork forums
I am currently doing an assignment on nuclear power and in the turbine, the steam is moving from pressure of 6Mpa to 0.008 Mpa. is there any way to work out the velocity of the steam when moving between these pressure differences?
Welcome! :)
The main reason you have that pressure differential is the blades and rotors of the steam turbine, which are stealing energy from the steam flow: therefore, that steam velocity at each section depends on that internal resistance to the flow.
Lnewqban said:
Welcome! :)
Thanks for your response!
How about if the system was treated as having no resistance to flow to work out a theoretical maximum velocity would there be a way to do this?
A change of pressure is involved for the mass of steam going through certain cross section; therefore, the specific volume at each section should be considered.
The conditions of steam could go from over-heated steam (turbine inlet) to sub-cooled condensate (turbine outlet) in a real turbine.
In your hypotetic case, the sudden pressure reduction could imply a sudden adiabatic increase of volume; resulting in a variable speed of steam for each cross-section of what would now be a duct rather than a entalphy degrading machine.
