World's Fastest Computers: Get Cluster Speed Advice
  • Thread starter Thread starter Sherwyn
    Speed
31 replies · 5K views
Sherwyn
Fastest Computer
Where would I find information on the fastest computers in the world?
Here is a http://www.top500.org/lists/2006/06"
can u convert 280.6 TFlop/s to a more managable unit?
also, how fast is one megaflop
Well I do not understand your question.
A flop is one floating point operation (an operation on a non-integer).
How fast is a Teraflop?
Can someone convert 280.6 TFlop/s to more managable units?
also, how fast is a megaflop?
What exactly is a cluster?
How fast are the fastest clusters, and does anyone know how fast the cluster(s) is/are at the University of Richmond?
My mistake
how many flops/s can any ordinary pc run? and how would i compare that to the fastest (280.6 TFlop/s)
woops. not how fast, but how many flops are in a megaflop, or a teraflop?
Mega and tera are both greek words.
Mega stands for 1 000 000
Tera stands for 1 000 000 000 000
prefix mega means 10^6 over the basic unit.
prefix giga means 10^9 over the basic unit.
prefix terra means 10^12 ...
so there are 1.000.000.000.000 flops in a terra flop
1.000.000.000 flops in a giga flop and so on...
These prefixes can be applied to any unit, not just to flops(i.e. MegaByte but here is a kinda different story because the basic units are in bynary not decimal.)
megaflop
A megaflop is a measure of a computer's speed and can be expressed as:
A million floating point operations per second
10 to the 6th power floating-point operations per second
2 to the 20th power FLOPS
http://whatis.techtarget.com/definition/0,,sid9_gci212543,00.html
Also http://en.wikipedia.org/wiki/Petaflops
megaFLOPS (MFLOPS) is equal to one million floating-point operations per second, and a gigaFLOPS (GFLOPS) is equal to one billion floating-point operations per second. A teraFLOPS (TFLOPS) is equal to one trillion floating-point operations per second.
http://www.webopedia.com/TERM/F/FLOPS.html
You should be able to calculate it with this information.
Well, 'terra' actually means 'ground' or 'land'. :wink:
It's 'tera' which is 1000 times bigger than 'giga'!
First, you know what the prefixes mean, right?
Kilo = 1,000
Mega = 1,000,000
Giga = 1,000,000,000
Tera = 1,000,000,000,000
For the processing power of pc's, hardware review sites have them. Here is a sample: http://www.tomshardware.com/2006/07/14/core2_duo_knocks_out_athlon_64/page16.html
Newer pc's are on the order of 10-20 gigaflops, so about 10,000 times slower than a supercomputer (which, incidentally, are often just clusters of several thousand desktop processors).
It is a term used in astrophysics, physics, chemistry, computer programming, computer disk drives. Maybe they have some really fast computers at the University of Richmond.
Check out http://en.wikipedia.org/wiki/Cluster_(physics)" .
AM
Serious Help needed
how do i found out how to run a test on a cluster to find out the speed?
Well that depends what you want to measure.
Is it pure CPU speed, for each CPU separately or on how they work togeter? Or is it disk throughput, like for some database application, network server performance? There are many things you can measure.
So it would help if you provided some more information.
Cluster Speed
How do i find out the speed of a cluster? I'm supposed to figure how to run a program to determine the speed of our cluster here at UR.
That's a rather vague question, as we don't know anything about UR's cluster. This sounds like some kind of a lab, though, meaning you should probably have some sort of handout that provides help.
There may a simple benchmarking program provided for you. Or maybe you have to write your own. If you have to write your own, of course, you'd have to use some kind of cluster library (MPI, etc.) to distribute the work across all the nodes in the cluster, which could be difficult.
If you have some kind of background information, you should provide it as part of your question. Otherwise, there's really nothing we can do to help you.
- Warren
I don't know really. I was told to just figure out how to determine how many megaflop/s its running and compare it to other clusters (specifically the faster ones). Should I have been given more information or what?
Well perhaps you could give us some context. Do you work there or do you study there? And is this request in anyway related to a program you follow?
To me it seems rather odd to ask someone, who aparently is not an expert about computers ("what is tera and mega", "what is a cluster", "how fast is a teraflop"), on how you determine the combined CPU speed of a cluster.
This is certainly not a trivial problem!
well, I am a freshman coming into the University of Richmond in the fall, and I am working with one of the physics professors and some of his students over the summer. I am in a program to help me get used the university and physics and whatnot.
Honestly, the best way to find this information is to look up who administers the cluster, and ask him/her. As we've said over and over in your multitude of threads on the topic, it's not a trivial question, nor does it have a trivial answer. It's also possible that the information you seek is on a University webpage somewhere, and you just need to find it.
- Warren
There are also super computers called "vector processors" that have many very fast arithmetic units within them, enough so that peforming an operation like a floating point multiply on two arrays of numbers and either storing the results in a 3rd array or summing the results occurs at the fastest speed that the machines memory can retrieve the input data. In the case of Cray super-computers, a vector processing system can be part of a cluster. Here is one link: http://www.cray.com/products/x1e and antoher: http://www.nec.com.au/products_detail.aspx?view=145
Cluster Websites
I'm still having trouble finding a website about finding out a cluster's speed. Anyone know any decent websites?
Cluster Websites
Anyone know any decent websites I could go to to learn about clusters and speeds and whatnot? I really need help on this one.
Hello Sherwyn,
I have absolutely no experience with computer clusters. :blushing: But the wikipedia entry might be something to start with:
http://en.wikipedia.org/wiki/Computer_cluster
As for speeds, there's a website/organisation that tries to keep track of all (known) supercomputers around the world. Here you can find the current top500 list:
http://www.top500.org/list/2006/06/100
Regards,
nazzard
Where could I find Cluster codes
Where would i find codes to run for a cluster to determine its speed?
Sherwyn,
Please do not post the same question multiple times. Your question is too vague to be answered as stated. Either come back to us and provide us the entire question or assignment you were given, or otherwise elaborate your question so that it actually has an answer.
As has been said, there are many different ways one can measure "speed" of a computer, and you're not giving us any information at all about what you're actually trying to do.
If you post this again, I will delete it.
- Warren
Admin note:
I have merged nine (!) of Sherwyn's threads into this one. All of these threads dealt with the exact same topic, finding the "speed" of an unnamed cluster at the University of Richmond.
- Warren
