WriterMaximization of Differentiable Real-Valued Function with Linear Variables
  • Level: Graduate
  • Thread starter Thread starter NaturePaper
    Maximization
3 replies · 2K views
NaturePaper
Hi everyone,
Suppose f =f(x_1, x_2,...,x_n) be a real-valued, any-time differentiable function. Let each x_i=x_i(u_1, u_2,...,u_{2^n-1}) be a linear function of reall u_i's. Let f=g(u_1, u_2,...,u_{2^n-1}). Then is it right that Max f w.r.t. x_i=Max of g w.r.t. u_i?
Sorry for the inconvenience of typo. I don't know how to use LateX fonts here.
Regards,
NaturePaper
If a f has a maximum, then that maximum is a specific number. That number is larger than all other values of f no matter what variables you are using. Thus, the answer is "yes". The maximum value of f is independent of the variables.
@HallsofIvy,
Does the result will change if all the primary variables x_i's are restricted to have values from an interval [a,b] subset of R?
Thanks & regards,
NaturePaper
If you also restrict the "u" variables so that the range is the set of permissible x variables, no the result does not change. Of course, if you allow values of the u variables that would give unallowed x values, then maxima might well be different.
