brotherbobby
- 806
- 178
- Homework Statement
- A vector ##\vec A## can always be expressed as the sum of a vector parallel to an arbitrary unit vector ##\hat n## and perpendicular to it.
(1) Split the vector ##\vec A## into the two parts,
(2) Verify the direction of each part as being tangential and normal, respectively.
- Relevant Equations
- Using the dot product, a vector can be projected along a unit vector chosen arbitrarily : ##A_n = \vec A\cdot\hat n.##
Shown in the image alongside, we are given a vector ##\boldsymbol{\vec A}## and a unit vector ##{\color{red}{\boldsymbol{\hat n}}}##. Effectively then, we are also given the unit vector perpendicular to it ##{\color{red}{\boldsymbol{\hat n}_{\perp}}}##. The vector ##\boldsymbol{\vec A}## is decomposed into two parts, along and perpendicular to the given vector :
\begin{equation}
\boldsymbol{\vec A} = \vec{A}_n+\vec{A}_{\perp n}
\end{equation}
Question : What are the vectors ##\vec{A}_n\;,\;\vec{A}_{\perp n}=?## in equation ##(1)## above?
Attempt : I could guess (see Relevant Equations above) that the vector parallel to ##{\color{red}{\boldsymbol{\hat n}}}## is ##\vec A_n=(\vec A\cdot \hat n)\hat n.{\Large\checkmark}## This matches with the answer given.
I have no clue as to how to go about with the other vector ##A_{\perp n}\; \hat{n}_{\perp}##. If I carried out a cross product ##\vec A_{\perp n}=\hat n\times\boldsymbol{\vec A}##, it would go out of the plane. That would not be fine according to my first doubt (see below).
Doubt(s) : I am afraid I have several.
(1) Is this problem valid only for 2 dimensions? (That's what it seems to me. In three dimensions, there is a plane perpendicular to ##{\color{red}{\boldsymbol{\hat n}}}## implying an indefinite number of unit vectors on the plane and perpendicular to the given unit vector, making the decomposition of ##\boldsymbol{\vec A}## non unique.)
(3) What is ##\vec A_{\perp n}##?
A hint or a clue would be of help.
