"y as a function of x" meaning
  • Level: High School
  • Thread starter sp3sp2sp
    Function
25 replies · 17K views · last reply
sp3sp2sp
If you are told to plot something as a function of something else, such as "pressure as a function of volume" would volume always go along x-axis? I mean what does it matter if you put volume on y-axis ,and then put pressure on x-axis? thanks
You could put pressure on the p-axis and volume on the v-axis.
It's only a convention to put the variable on the ##x-##axis and the value on the ##y-##axis, as e.g. also in bar charts. There are all kind of diagrams out there: non-linear scaling, two value axis for different quantities or what so ever. It is all about readability, and it avoids a lot of confusion and unnecessary discussions to follow conventions.
OK thanks but so when professor asks for this as a function of that, I should be thinking plot this on x and that on y, right? (because for one reason its convention)?
Usually, yes. It's faster to read. However, there might be circumstances, where it is different: form of paper, resp. printer, multiple values, the need to mirror the function along the diagonal etc. But usually we have as a function ##f(x)=y(x)=y\,.##
"when professor asks for this as a function of that, I should be thinking plot this on x and that on y, right? (because for one reason its convention)?"
no, just the opposite is the usual convention. i.e. here "this" = y and "that" = x.
yup that's actually what i meant..i just reread and just got them mixed up..thank you.
Is it possible to make a curved line graph linear? I tried squaring x-values , but doesn't that mean I would have to also square y-values = exact same graph? thanks
You can rescale axes - sometimes this makes relations easier to see, sometimes it doesn't. It depends on your function. As an example, ##f(x)=e^x## is a straight line if you make the y-axis logarithmic.
I have plotted moment of inertia as a function of radius using 4 data points and I am asked if this graph is linear but the plot is is not smooth at all even though it definitely has positive slope. Then I am asked what I could do to make the plot linear and wouldn't this just be getting the equation? Its y = (1.374e-2)x - 5.706e-4
thanks for any more help
First answer, yes. The vertical axis is coordinates for the function and dependent variable, and horizontal axis is for coordinates for the independent variable. The FUNCTION has inputs of your volume values.
I have graphed inertia as function of radius and the curve looks exponential. I want to linearize the curve. If I take log of all the y-values would that work and does that make math sense to do that? thanks for any help
Yes you could do that, I have seen it been used a few times in some Physics Olympiad questions. However, why you want to do it is up to you.
Do you expect an exponential function?
It is not linear, sure, but not everything nonlinear is exponential.
That is a linear equation, but where did it come from? If the four data points you mentioned in post 10 lie on a curve, then the above could not possibly be the equation of the graph the data points lie on.
After I make it linear the slope should = the mass shouldn't it? It looks exponential, I mean I am not sure what else to call it. It intercepts at origin and increases with curved pos slope. thanks for the help
Inertia and radius of what? It would help a lot if you tell us some details of the experiment or situation that you are trying to analyze.
[added] OK, now I've seen your other current thread. Are you discussing the same situation as in that thread, and by "inertia" do you mean "moment of inertia"?
If the two threads are about the same situation, we'll merge them together for you.
I no longer know much from Physics or Mechanics, but if you have original data which would fit a curve for an exponential function, you could treat your data or your model equation so that it would work as a linear function. One set of coordinates might go onto semilog number scale and the other set of corresponding coordinates could go on to a linear number scale and if you have something that looks like a line, then you could form the necessary equation. Other members can explain this better and show it.
I have merged the two threads, as I suspected we were still talking about the function in your post #10. If so, the answers you will get to your post #12 will be misguiding. If I'm wrong, then just mention what exactly you have plotted.
its OK its a lab that's already completed. It was time sensitive question that's why I thought I would ask the exact issue I was having but it turns out I just needed to square the R value to linearize the plot. (because I = .5MR^2).. That was the problem i was having: How to linearize moment of inertia vs radius plot Thank you for all the help.
You can run a regresion analysis and try to deetmine the best fit through it. Linarity is given in terms of the coefficients, not the variables. If you have differentiability you may use the inverse / implicit function theorems.
I'm not a mathematician, but my old maths teacher told me that log-log works for most equations I'll meet.
If you expect it to be x, x^2, x^3 , 1/x , √x , etc. then it will tell you which.
This is just some made up data:
Two charts side by side: left, a scatter plot of L against r with a fitted curve rising steeply; right, a log(l) against log(r) scatter plot with a straight trend line, annotated y = 1.9863x + 0.4883 and a small table of r, l, log(r) and log(l) values above.
BTW the lines were sketched by Excel just for speed and convenience. I don't like that and would get a better line by hand, when I know what answer I want ! Only joking, but humans really can do better, because we know the 0,0 must be on the line even though we can't collect that data.
  • Two charts side by side: left, a scatter plot of L against r with a fitted curve rising steeply; right, a log(l) against log(r) scatter plot with a straight trend line, annotated y = 1.9863x + 0.4883 and a small table of r, l, log(r) and log(l) values above.
But (0,0) does not seem to be on your graph. For "standard" regression we have that ( x-bar, y-bar) are in the least squares line of best fit.
You can force the fit to go through that line.
Not all lines have to go through 0,0.
I don't know how to measure that data point: zero radius is impracticable.
I should have simply selected the option in Excel to force the line through 0,0 as suggested by MFB. I only thought about that when I noticed Excel had done it wrong and I forgot that it has such an option.
But this line does. Even if you don't yet know the form of the function for moment of inertia, you do know that if an object had all its mass concentrated at zero radius, it would have zero moment of inertia.
It is very traditional to use the horizontal axis as the independent variable and the vertical axis as the dependent variable. You can and should perform translations (like log(y)) if it makes the graph easier to use and to read the numbers of interest from. Just be sure that the axis is labeled correctly "log(pressure)" and that the numbers reflect that (values of log(pressure) rather than of pressure). Alternatively, you can position the dependent values in their log(pressure) position, but label that axis as pressure and put the pressure numerical values at that axis position.
Although using the variables "x" and "y" to describe a graph is very common, you should get in the habit of using the correct variable (like "pressure" and "volume") when you talk about a specific graph and use "horizontal axis" rather than "x axis" and "vertical axis" rather than "y axis" when describing the layout of a general graph.
