Y=KX^n Graphing and Coefficient
5 replies · 17K views · last reply
lunapt
So there's this graph in chemistry with a curved negative slope shape.
(x, y)
(0.16, 104.61)
(0.26, 39.62)
(0.35, 21.86)
(0.56, 8.54)
(0.70, 5.47)
(0.98, 2.79)
The equation is y=KX^N
1) What is the value of N for which the graph would be a straight line?
2) What is the value of K for which the graph would be a straight line?
No idea how to do this.
(x, y)
(0.16, 104.61)
(0.26, 39.62)
(0.35, 21.86)
(0.56, 8.54)
(0.70, 5.47)
(0.98, 2.79)
Using purely qualitative understanding of functions, you would expect any equation of the form, y=kx where y is the dependent varialbe, x is the dependent variable, and k is any real nonzero number constant, the be an equation for a line. Knowing that, if you wished y=kx^n to be a line, then n=1, and again, k is any real constant not equal to zero.
Your (x, y) data show x going through one cycle of 10 and y going through about two cycles of 10. An exponential fit might be reasonable to try. You get a better idea if you plot the points on cartesian paper. Maybe semilog paper, too.
i tried exponentially, and if i put in logy and input y values, then its almost a straight line...
how do i find n?
Welcome to PF, lunapt!:
Consider that:
[itex]y=K X^N[/itex]
[itex]\log y=\log(K X^N)[/itex]
[itex]\log y=\log K + N \log X[/itex]
The method would be to set up the regular equation for a line.
And then match the coefficients with log(K) and N.
However, it seems to me that your equation wouldn't fit (but I did not work it out).
It seems more likely that your relation is [itex]y=K N^X[/itex].
So:
[itex]\log y = \log(K N^X)[/itex]
[itex]\log y = \log K + X \log N[/itex]
lunapt,
Your points plotted on a cartesian system directly appear like exponential decay. Your points when treated as Log(y) versus Log(x) and then plotted seem to give a very clean, accurate, line.
