What Wavelengths of Light are Used in Young's Double Slit Experiment?
In Young's Double Slit Experiment, the fringe separation (Δy) is calculated using the formula Δy = λL/d, where λ represents the wavelength of light, L is the distance to the screen, and d is the slit separation. The discussion highlights confusion regarding the correct values for wavelengths, suggesting using approximately 650 nm for red light and 475 nm for blue light. It emphasizes that Δy is the fringe separation, while d refers to the distance between the slits, which is crucial for accurate calculations. The importance of adhering to conventional definitions in physics is noted to avoid confusion. Understanding these terms is essential for solving related problems effectively.
5ymmetrica1
using the formula Δy = λL/ d calculate the fringe separation (d) for the red and blue light used in the experiment
as above
So I rearranged the equation to read
d = λL / Δy
and I'm fine with the math, but I don't understand what wavelength to use, as the following question is.
Using (d) found in the previous question, find the wavelength of the red and blue light used in the experiment.
So say I have
Δy = 5.00 x 10-4m
L = 0.25 m
The equations would be
d = 0.25λ / 5.00 x 10-4
am I supposed to use a separate equation for this formula or do I just use an approximate length of red light such as 450nm?
I think that you have the terms in the equation confused.
Δy is the fringe separation. d is the distance between the slits (the slit separation)
Does it matter?
rude man said:
Does it matter?
Only that the equation Δy = λL/d is the more or less standard equation to calculate fringe separation Δy.
Of course you can use any 4 symbols you like and give your own definition of each symbol. That would probably cause some confusion but you would probably get the correct answer.
There must be a good reason why Δy is commonly taken to be a separation between the fringes rather than the distance between the slits.
d is usually taken to be the distance between the slits, as it also is in analysing diffraction gratings.
Keep life (in physics) as simple and conventional as possible. But you are perfectly correct...does it matter.
