Yukawa potential energy function
3 replies · 6K views
astenroo
This is not yet an attempt at solving a problem. I just need confirmation on that I'm on the right track. So, I am supposed to derive an expression for the radial force function from the given Yukawa-function.
U(r) = -(r/r0)U0 exp-(-r/r0)
I'm thinking about two possibilities here. First: Derivation of said function with respect to r (normal differential). Second: Partial differentiation to solve for the gradient (although I think this is not necessary since r is a fixed value, and no coordinates are given in the context of the problem)
RoyalCat said:
[tex]\vec F = -\nabla U[/tex]
http://en.wikipedia.org/wiki/Del_in_cylindrical_and_spherical_coordinates
In this case the normal derivative is the same as the partial derivative.
Ah true, since this function only has one variable which is r. What I am a bit concerned about is that if the system for spherical coordinates should be used in this derivation... Or they aren't needed since the radial force is dependent only on r (in this given situation)?
It doesn't matter, you have only one axis specified in the problem, and that's the radial axis. The way to take the gradient with respect to the radial axis is [tex]\frac{\partial f}{\partial r}\hat r[/tex]
It doesn't matter what the other two axes are.
