Z-coordinate shift when using elliptical integrals?
  • Level: Graduate
  • Thread starter Helmholtzerton
    Integrals Shift
2 replies · 1K views · last reply
Helmholtzerton
Hello,
I'm wondering if my approach to a problem is correct as when I try to simulate the DC magnetic field of a current loop using elliptical integrals, I obtain results that appear incorrect when shifting the current loop's location from the origin of the z axis.
I have attached the mathematical expressions along with my results.
  • Elliptical Integral Question.docx
  • Top: printed formula for Bz with elliptic integrals K(k) and E(k), with definitions of a, b and k. Bottom: colour heatmap titled Gauss(Z) of a simulated field, Z position [mm] on x-axis, X position [mm] on y-axis, colour scale G from 2 to 20, high values at two spots near Z = 0.
  • Colour contour plot titled Gauss(Z), showing field magnitude in G against Z position in mm from -0.05 to 0.25 and vertical position from -0.06 to 0.06, with peaks near the top and bottom edges at several Z positions and a colour scale from about 5 to 25.
Helmholtzerton said:
Hello,
I was unable to view the "link" on my computer. I think I wound up evaluating a similar integral in a write-up I did where I showed the Biot-Savart integral from some surface currents gives the exact same result as the pole method. I only evaluated the integral in the plane of the endface of a cylinder of semi-infinite length: See: https://www.overleaf.com/read/kdhnbkpypxfk
Thanks for the reply Charles,
There was an error in my code.
I have achieved symmetry.
