Understanding Zeeman Splitting: Predicting Components in Weak Applied Fields
  • Thread starter Thread starter hhhmortal
    Splitting Zeeman
This discussion focuses on Zeeman splitting, specifically predicting the components produced in weak applied fields. For the normal Zeeman triplet, the transition 1D2 to 1P1 or 2P(3/2) to 2S(1/2) is identified as correct, contingent on having an even number of electrons forming a state with S=0. The sodium resonance line, originally a doublet at 589.6nm, splits into four components with a frequency difference of 2/3 Lorentz unit (LU) and six components for the 589.0nm line, with identical frequency differences.
  • Understanding of Zeeman effect and its implications in atomic transitions.
  • Familiarity with sodium's resonance lines and their spectral characteristics.
  • Knowledge of quantum numbers and selection rules, particularly the transition rule Δm = +1, 0, -1.
  • Basic grasp of Lorentz units (LU) in the context of spectral line splitting.
  • Study the detailed mechanics of the Zeeman effect in various atomic systems.
  • Explore the calculation of Lande g-factor for multi-electron atoms.
  • Investigate the implications of weak vs. strong magnetic fields on atomic transitions.
  • Learn about the application of quantum mechanics in predicting spectral line behavior.
Physicists, particularly those specializing in atomic physics, students studying quantum mechanics, and researchers focused on spectroscopy and magnetic field interactions with matter.
hhhmortal
(Q1) Which transition will produce a normal zeeman triplet in a weak applied field?
(Q2) The sodium resonance line is a doublet. What is the total number of components that appear when the line is split by a weak applied field?
(Q1) 1D2 --> 1P1 or 2P(3/2) ---> 2S(1/2) ?
q1. Seems correct - remember you can't shift between states with the same l-number.
The visual effect above is awful, sorry.
1. Sufficient and neccesary conditions for normal Zeeman triplet is:
The total number of electrons is even, and the electrons form the state with S=0, 2S+1=1.
2. As to the famous sodium doublet, the 589.6nm line will split into four lines, with frequency difference 2/3 Lorentz unit (LU), 3/4 LU, 2/3 LU, respectively; the 589.0nm line splits into six ones, with identical frequency difference of 2/3 LU. No line exists at the initial location any more.
Comments:
1. Sodium Doublet: 589.6nm: 2P_(3/2) ----->2S_(1/2), 589.0nm: 2P_(1/2) ----->2S_(1/2).
2. Transition Rule: \Delta m = +1, 0, -1.
589.0nm: 2P_(1/2) ----->2S_(1/2), m, mg
---|----------------------------------------------------- 3/2, 2
---|---------|----|-------------------------------------- 1/2, 2/3
---|---------|----|---------|----|---------------------- -1/2, -2/3
---|---------|----|---------|----|----------|----------- -3/2, -2
1 1 1 1 1 1
1 1 1 1 1 1
1 1 1 1 1 1
---|---------|----|---------|----|----------|----------- 1/2, 1
------------------|--------------|----------|----------- -1/2, -1
589.6nm: 2P_(1/2) ----->2S_(1/2), m, mg
---|---------------------------------------------------- 1/2, 2/3
---|---|-----------------|----|------------------------- -1/2, -2/3
1 1 1 1
1 1 1 1
1 1 1 1
---|---|-----------------|----|-------------------------- 1/2, 1
-------|----------------------|-------------------------- -1/2, -1
where $g$ above is Lande g fractor, and for effectively mono-electron atoms, such as 1H, 3Li, 11Na, 19K, 29Cu, 47Ag, 79Au,
3 1 S * (S+1) -- L * (L+1)
g = --- + --- (---------------------------------)
2 2 J * (J+1)
