Equal Forces of Attraction and Repulsion for Like Charges in Coulomb's Law?
  • Thread starter Thread starter Procrastinate
    Coulomb's law Law
The discussion clarifies that the force of attraction between a positive and negative charge (e.g., -1C and +1C) is equal to the force of repulsion between two like charges (e.g., +1C and +1C), provided they are the same distance apart. This relationship is explained by Coulomb's law, which governs electrostatic forces. Participants encourage practical application by suggesting to plug values into the formula to observe the outcomes. Understanding this principle is essential for grasping electrostatics concepts. The discussion emphasizes the consistency of electrostatic forces regardless of charge polarity.
Procrastinate
If I have a positive and negative charge, say -1C and +1C, will the force of attraction be the same as the force of repulsion for a +1C and a +1C charge?
I've been trying to teach this electrostatics chapter to myself before term commences so I can get a bit of a head start.
Yes. (Assuming the charges are the same distance apart, of course.) The force is given by Coulomb's law.
Try plugging some values into the equation for the force of electrostatic repulsion/attraction and see what happens =]
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
