Thermodynamics - Entropy and Temperature
The discussion focuses on the thermodynamic principles of entropy and temperature as a gas expands and compresses in a closed system. When the gas expands into the piston chamber, its entropy increases due to the increase in volume, while the temperature drops. Conversely, during compression, the volume decreases, leading to a decrease in entropy and an increase in temperature. The key equations referenced include S = Q/T, PV = nRT, and ΔU = ΔQ - ΔW, which are essential for analyzing the thermodynamic cycle.
  • Understanding of thermodynamic laws, particularly the first law of thermodynamics.
  • Familiarity with the concept of entropy and its mathematical definition.
  • Knowledge of the ideal gas law (PV = nRT).
  • Ability to perform calculus-based integration for thermodynamic equations.
  • Study the derivation and application of the entropy formula ΔS = ∫(dQ_rev/T).
  • Learn about the first law of thermodynamics and its implications for internal energy changes.
  • Explore the concept of reversible and irreversible processes in thermodynamics.
  • Investigate the relationship between temperature, pressure, and volume in ideal gases using PV diagrams.
Students of thermodynamics, physics enthusiasts, and professionals in engineering fields who require a deeper understanding of entropy and temperature dynamics in gas systems.
lifeonfire
A gas fills a closed chamber connected to an evacuated piston chamber via a valve. The apparatus is diathermal (heat can flow through the walls of the chamber). The valve is opened to vent the gas into the piston. The piston then slowly compresses the gas back into the original chamber. Explain what is happening to the entropy during the cycle.
S = Q/T; PV = nRT; ΔU = ΔQ - ΔW
Step 1: Gas comes out from the chamber into the piston chamber. It expands in volume. So the entropy increases? And the temperature of the gas will drop?
Step 2: When gas is compressed, volume decreases and so entropy decreases and temperature will increase??
Help! i don't think I am doing it correctly...
Apply the definition of entropy:
[itex]\Delta S = \int \frac{dQ_{rev}}{T}[/itex]
Compare the initial and final states of each step by applying the first law. Determine the reversible path between the two states. Write the expression for dQ_rev/T and integrate.
In the first step, is there any work done? Is there any heat flow? If not, what can you say about the change in internal energy? What does that say about the change in temperature?
Answer those questions first.
AM
  • · Replies 67 ·
  • · Replies 33 ·
