Intuitively d'Alembert's solution to 1D wave equation
ralqs
D'Alembert's solution to the wave equation is
u(x,t) = \frac{1}{2}(\phi(x+ct) + \phi(x-ct)) + \frac{1}{2c}\int_{x-ct}^{x+ct} \psi(\xi)d\xi where \phi(x) = u(x,0) and \psi(x) = u_t (x,0). I'm trying to understand this intuitively. The first term I get: a function like f = 0 (x/=0), = a (x=0) will "break into two functions" and become f = a/2 (x = +/- ct), = 0 (x /= +/- ct). But I can't see how the integral term comes about. Does anyone here have a good physical intuition about this? Thanks.
Likes bosque
The integral comes from the initial conditions. In particular the fact that we are given a derivative of our solution so our solution must be an integral of what we are given. Think of it in two steps.
We have the operator
(Dt)2-(c Dx)2=(Dt+c Dx)(Dt-c Dx)
In the factored form it is easy to see our solution is the sum of two parts. In one x+ct is held constant and in the other c-ct is constant.
f(x+ct)+g(x-ct)
Then apply the Cauchy boundary condition and preform some elementary algebra to express the solution in terms of the Cauchy data.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
