# of elecron/sec in a 3 bulb circuit
  • Thread starter Thread starter iknowless
    Bulb Circuit
In the discussion, it is established that a single round bulb allows 5 x 10^18 electrons to pass through per second, while a long bulb permits only 2.5 x 10^18 electrons due to its smaller cross-sectional area. The conversation revolves around using Kirchhoff's rules and the relationship between electric field, current, and cross-sectional area to analyze the circuits. Participants explore the implications of these relationships without relying on Ohm's Law, focusing instead on electron mobility and current equations. A correction is noted regarding the formula for the closed path in the circuit, emphasizing the importance of accurately representing the circuit's configuration. The discussion concludes with an acknowledgment that further algebraic manipulation is required to solve the problem.
iknowless
When a single round bulb of a particular kind and two batteries are connected in series, 5* 10^18 electrons pass through the bulb every second. When a single long bulb of a particular kind and two batteries are connected in series, only 2.5*10^18 electrons pass through the bulb every second, because the filament has a smaller cross section.Figure 18.68
In the circuit shown in Figure 18.68, how many electrons per second flow through the long bulb?
E is the electric field in the filament
A is the cross-sectional area of the filament
i is electron current
l is the length of the filament
n is the # of electrons per unit volume (unknown)
u is the electron mobility (unknown)
Circuit 1 is the main circuit, with long bulb A, and two identical round bulbs, both labeled B.
Circuit 2 is the circuit with 1 long bulb, C.
Circuit 3 is the circuit with 1 round bulb, D
i_1=nA_auE_a=n2A_buE_b
i_2=nA_auE_c=2.5e18
i_3=nA_buE_d=5e18
2emf=l(E_a+2E_b)=E_c l=E_d l
note: A_b>A_a
E_c=E_d
I am assuming that all the filaments have a length 'l.'
I have created fractions of current to produce some hopefully useful formulae.
From i_1, A_a E_a=2A_b E_b
From \frac{i_1}{i_2}, E_a i_2 =2 E_b i_3
Also, i_1=\frac{E_a i_2}{E_c}=\frac{2 E_b i_3}{E_c}
And \frac{i_2}{i_3} = \frac{A_a}{A_b}
E_a+2E_b=2E_b+E_b \frac{i_3}{i_2}=E_c
Please just give me a nudge in the right direction. Thanks!
Isn't it just about voltage, current and combining resistances?
We haven't talked about resistance or Ohm's law yet. We can only use Kirchhoff's node rule,
"In the steady state, the electron current entering a node in a circuit is equal to the electron current leaving the node."
We can also use "i=nAuE" and the Loop Rule, where voltage around a closed path is zero in a circuit.
Is there an easier way to do it with resistance? Please help, but I would also like to know how to do it without Ohm's Law.
Wow, how did I not see it? In formula 4
Then A_b=2A_a !
So now formula 1 can be written as E_a=4E_b
There is an error in the 4th relevant equation. It should be 2emf=l(E_a+E_b)=lE_c because the closed path only travels through 1 round bulb, not 2.
and the rest is algebra
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
